Lighting issue in need of ideas
Hey everyone so last week I picked up a 01 2500 v10 and I thought I got a great deal on it, turns out it was the opposite. I have quite a few problems and ill probably post a few other threads on that, but I'm going to start with this. As of right now my low beams don't work but highs do. My running lights and cab lights work too. My turn signals don't flash they just stay lit. Then there is the rears.. I have nothing! No running lights brake or turn signals. I do know I am getting power to the sockets but something is now allowing it to call. Any ideas on what it could be??
For the turns: Do the same as step 2 for the lows I suspect either a bad ground or multifunctional switch
For the rear: Same as step 2 for the lows
Post back what you find out and I'll help you from there. I had basically every electrical problem known to man on these trucks so I'm pretty much an expert
Start simple first. You've tested power to the sockets, right? Pop the cover to the fuses (there's two - one under the hood and one in the cab on the side of the dash). The flasher is in the dash panel. Replace that. Then replace bulbs and see what gives. Might have bad relays too. Check for mice nests as they will eat wires.
Could also be an issue with the switches on the dash (both light and multi-function). Check all that and report back.
it's a two bulb system.
I check the rear tail lights with an ohm meter and im getting power to the socket. I also tried swapping out my headlight switch with the one from my 98 ram because i knew it worked, but had no change. So I'm still at a loss and can't figure out what's going on.
Headlight switch provides ground path for your lights. Since your high beams work, that means you are getting power TO the lights at least. No low beams indicate that you are not getting a ground for those. (or, both bulbs are bad......) Need to find out where you are losing the circuit. If I had to hazard a guess, it would be the multifunction switch in the steering column. (which may also explain why some of your other lights don't work either.)
Okay so my lights are somewhat fixed! Mainly my rear lights, after testing and testing I found out that I had a bad ground by means of a broken wire. I've replaced my headlight switch but it didn't make a difference so I'm still having trouble with the low beam lights. I have a feeling it's my multi function switch but haven't gotten around to swapping it out.
