A.C. Schrader Valves
Old 06-16-2018, 08:56 AM
Ramchu's Avatar
Ramchu
Ramchu is offline
Default A.C. Schrader Valves
1996 Ram 1500
Does anyone know if the Schrader Valves in the A.C. system are a standard size or something special.
Mine are leaking, both High and low pressure sides and need to be changed.
I found this Four Seasons kit on RockAuto, but would like to buy locally if possible.
Old 06-16-2018, 09:55 AM
Could probably order it from your local parts store......
Old 06-16-2018, 10:07 AM
Ramchu's Avatar
Ramchu
Ramchu is offline
Yes you are correct, in fact one of the local stores actually has one of the kits in stock.
My question is are they a special size ?
Old 06-16-2018, 10:14 AM
I think they are specific to the refrigerant they are designed to be used with.
Old 06-16-2018, 12:07 PM
racefan41's Avatar
racefan41
racefan41 is offline
In my experience, Rockauto is reliable with knowing what parts are going to work for vehicle. Do they give options for different kits? Is the part store able to pull up any part number for you to compare?
Old 06-17-2018, 09:11 AM
Moparite's Avatar
Moparite
Moparite is offline
Remove the old ones and look at the link, It will tell you what you have/need.
http://www.schraderinternational.com...e_10-21-13.pdf
Old 06-17-2018, 03:06 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Very good information. Thanks for sharing this.
Old 06-18-2018, 09:34 AM
Ramchu's Avatar
Ramchu
Ramchu is offline
Thanks, Just what I needed !
Quick Reply: A.C. Schrader Valves
