Got an electrical connector hanging Dow and I dont know where it goes.
Your looking in through the drivers side headlight opening. I removed it to try and trace where this wire should go. To the left the wire mounts to one of the bolts holding in the headlight. Then there’s the one which leads up and is connected to the side there with a pushpin. The the other one at the bottom is the one I don’t know about.
Today I went out to check something under my truck and saw a wire hanging down. I don’t know where it goes. I looked around for a good bit, but I can’t see it. Anyway I took this picture hopefully one of you guys will know.
no fog lights, but I just checked and the first selection on the light switch does nothing. The second selection does get the head lights working. I looked in the manual. It says the first selector is for parking lights. I never use them so I didn’t even know what it did.
I thought I’d check again just to make sure. It’s really hard to see in the daylight, but yes the parking lights seem to be working. I was really just hoping someone with the same truck could take a quick look and tell me where that connector goes. Because I don’t know what it’s for. It doesn’t lead to the lights. That was just the only place for me to gain access to try and see. The upper wire is going up around the side of the fuse box and the wire to the left is a ground which is just mounted to a bolt that holds in the headlight assembly. The other wire was just hanging under the truck when I went under to check for a steering leak earlier today. Do you have a 3rd Gen?
does anyone out there own one of these trucks and could take a quick look where that wire goes? Please and thank you
