Idle fluctuation issues
Hi everyone, im new to this forum but a long time dodge owner and DIYer so im looking for some help that I cant seem to find the answer to on the good old fashioned internet.
here is my issue:
Idel fluctuates from 1000-3500 rpms only when I engage the fan and start to blow air. doesn't matter if the AC is on or not. No CEL.
what ive tried:
1. replaced the IAC a couple times and this doesn't seem to help
2. throttle body has been cleaned a couple times- no difference
3. tested for vacuum leaks and there arent any that im aware of.
4. replaced the breather pipe and hose as there was a small crack- no difference
5. sprayed WD-40 around a bunch of hoses to see if I could detect any sort of vacuum leak- couldnt find any.
6. replaced blower motor
my thoughts of what to try next-
-MAP replace
-Throttle position sensor replace
not sure if this will help or not as it seems the issue is tied to the motor kicking on and blowing air which throws off the idle. thanks to anyone that can point me in the right direction here!
here is my issue:
what ive tried:
-MAP replace
