Where can i buy an intermediate steering shaft?
Old 09-24-2018, 02:18 PM
coledurgan's Avatar
coledurgan
coledurgan is offline
Default Where can i buy an intermediate steering shaft?
Have looked everywhere online and i cannot find an intermediate steering shaft for my 93 dakota 3.9L 2wd. anybody know where i can get one??
Old 09-24-2018, 03:03 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
IDK I looked around recalling a post on here by someone and I found this https://dodgeforum.com/forum/1st-gen...ate-shaft.html
His is a 88 but its first gen. IDK if there is a difference
Old 09-24-2018, 06:23 PM
tbugden's Avatar
tbugden
tbugden is offline
3 people I know of on this forum have done it, RalphP, crazy4x4rt and myself. We've all built our own out of a shaft and u joints from Borgeson(edit: Ralph used classic performance not Borgeson). No parts store replacements available.
Old 09-25-2018, 08:57 AM
coledurgan's Avatar
coledurgan
after a days worth of research i UNFORTUNATELY concur with both of you.. Looks like building my own would be the best option.
Old 09-25-2018, 09:00 AM
tbugden's Avatar
tbugden
tbugden is offline
It's really easy, just need a hacksaw to cut the shaft to length then everything bolts up. Much more difficult to get the old one off.
Just sucks that it's pretty expensive but you don't wanna skimp on steering.
Old 09-25-2018, 10:56 AM
coledurgan's Avatar
coledurgan
How well does it steer now that you have replaced vs before?
Old 09-25-2018, 01:11 PM
tbugden's Avatar
tbugden
tbugden is offline
Better. The stock u joints had a ton of play. you won't feel a difference probably unless your ujoints are pretty bad.
Old 09-25-2018, 01:57 PM
coledurgan's Avatar
coledurgan
haha. i will post pics when i get home. I am confident if i keep driving it im going to lose steering going down the road.
Old 09-25-2018, 08:31 PM
tbugden's Avatar
tbugden
tbugden is offline
Thars the thing. I have a pretty low threshold for deciding that steering components need to be replaced. Brakes and steering are two things you want to have confidence in.
Old 09-25-2018, 09:24 PM
RalphP's Avatar
RalphP
RalphP is offline
I don't know if approx. $100 is "pretty expensive", compared to the other choice (finding cheap stuff to hit when the current linkage breaks!)
I'll add an angle grinder or sanding disc is not a bad idea, to rechamfer the end you cut so it slides in and out a bit better.
What one guy did on another forum is, after he got his linkage all right and adjusted, he took each set screw out one at a time, did a small drill right smackdab in the middle with a 1/8" drill bit (just enough to mark it!), pulled the shaft, and drilled a shallow countersink with a 1/4" drill bit, to give the set screw something to bite on.
I just crank'er down with LokTite Blue on the threads myself.
Aside: There's a spot on the tilt column bottom end where the old roll pin went that's just perfect to bit into with the set screw; the rack & pinion end was also just about perfect to bite into with the set screw there.
As to feel ... well, I'm a bit better aquainted with the bumps and expansion joints between the steel U-joints and the poly control arm bushings
But it's not objectionable; and a LOT better than the previous "I turned the wheel, why isn't it turn .. oh, THERE it goes!" IMO.
RwP
Quick Reply: Where can i buy an intermediate steering shaft?
