Bad torque converter solenoid
Old 10-14-2018, 07:55 PM
Gman63's Avatar
Gman63
Gman63 is offline
Default Bad torque converter solenoid
2001 S1500 4x4. Got a bad torque converter code. Can I still tow my 5000 Lb trailer if I turn the overdrive off?
Old 10-14-2018, 09:26 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
I wouldn't. You are suppose to have OD off when towing anyhow
Old 10-14-2018, 09:59 PM
Gman63's Avatar
Gman63
Gman63 is offline
Thank you. I know it is not recommended but would I be ok going from St Paul to Nortwest Arkansas if I turn overdrive off at this point. Unfortunately, the person I bought the trailer from had always left his on and never had a problem. First time I have owned a trailer this heavy.
Old 10-15-2018, 07:20 AM
You want to fix it before you go. Otherwise, you will likely end up on the side of the road with a burnt transmission.
What code are you getting?
Old 10-16-2018, 01:49 PM
Nick Bain's Avatar
Nick Bain
Nick Bain is offline
Does the rpms stay steady while in OD? mine were wandering quite rampantly before the tranny pooped the bed and I was also getting a TC code
Quick Reply: Bad torque converter solenoid
