I need help serious cold start issues 318
Old 10-20-2018, 09:05 PM
Jake1214's Avatar
Jake1214
Jake1214 is offline
Default I need help serious cold start issues 92 d150 318
1993 dodge d150 318 fuel injected
so I have this issue with cold starting, when the engine is cold it will fire right up, at times it will instantly have issues while at other times these issues will arise after 5-10 minutes idling or driving. Here's what the issue is, the motor will hessitate bog down rev back up, pop in the exhaust if you accelerate it, if you are driving it will loose power to the point i have to pull off the road until it is warm, it will die sometimes even idling it has stalled out and died as many as 20 times before working correctly and I'll have to start it several times untill it reaches operating tempeture while this is happening the battery guage lowers too but never below 10. When the engine is warm it runs fine and has no issues no matter how long you drive it. I've had the battery and alternator tested they are fine I've replaced spark plugs gap set at 35, wires, ignition coil,( distributor looks new no grime on it), fuel pump and filter, cam/crank sensor, coolant temp sensor, manifold temp sensor, throttle position sensor, cleaned out breather, cleaned egr valve, cleaned pcv, cleaned (partially) throttle body, cleaned idle control valve, I've checked to see if plenum gasket is blown it might be doesn't have significant vacuum from breather if pcv is unplugged and blocked off, but inside intake looks dirty, I have had this at a mechanic shop two months they can't find the issue I've been trying to fix it myself but cannot seem to find the issue if anyone can help me with this I will greatly appreciate it
Old 10-20-2018, 09:12 PM
Jake1214's Avatar
Jake1214
Jake1214 is offline
I can tell you the codes it throws but none seem to be related or I've replaced those parts
Old 10-20-2018, 09:21 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
considering the long list of parts about the only thing that might be left is probably the computer. it may also explain why the issue is not immediate every time
Old 10-20-2018, 10:15 PM
Jake1214's Avatar
Jake1214
Jake1214 is offline
I haven't thought of this but I am not sure that a faulty pcm or ecm would only cause cold start and cold running issues and not give me problems after warmed up to operating tempeture also I've hared a blown plenum could cause this but I really hope it's not the issue I don't have the time money or tools to replace it, it comes as a three peice set all of which I probably would need because I highly doubt the stock steel plenum plate has been upgraded to an aluminum one this may also be a compression issue I've not had compression tested yet and I have no idea how many miles are on this truck or if the motor is original casting numbers match but can't find Vin on block odometer does not work and is stuck at 90960 I had a Camaro that needed new intake gasket and it was quite the ordeal took me two days to get it on there and get the timing set also I am throwing a code saying timing chain has skipped one of more teeth I am not sure if this could cause this issue or is actually a result of this issue
Old 10-20-2018, 10:41 PM
crazzywolfie
i know someone that use to have a 93 that never liked starting in the cold but roll it into the heated shop and let it sit for a bit and it would all of a sudden start working like it should. computers can start getting temperamental and failing with age.
Old 10-20-2018, 10:48 PM
Jake1214's Avatar
Jake1214
Jake1214 is offline
Ah, I will have this checked if a test can possibly be done on it. Do you know if there is a test for it? Also it's not cold outside really maybe 50 or 45 degrees at it's lowest asaof recent. The tempet has just began dropping here in Arkansas, this may make sense though after I replaced/ cleaned several parts today (replaced coolant temp sensor and manifold temp sensor, cleaned egr, pcv, and idcv,) the engine was vounerable to ambiant sunlight and still warm to the touch.
Old 10-20-2018, 10:52 PM
Jake1214's Avatar
Jake1214
Jake1214 is offline
I am no ase certified mechanic by any means by the way but am somewhat knoledgable of how a vehicle works ( if I was forced to build my own engine I could accomplish it with the proper tools)
Old 10-21-2018, 09:00 AM
HeyYou is online now
List the codes anyway.
Try unplugging the O2 sensor, and see if anything changes.
Old 10-21-2018, 09:48 AM
Jake1214's Avatar
Jake1214
Jake1214 is offline
Forgot to mention that o2 sensor was replaced as well... Hard to keep up with this long list of parts I've put in it lol might be something else missing
Codes
12 battery unplugged
11 skipped teeth on timing chain/belt
24 throttle position sensor out of range... It's new
54 no cam signal at pcm, cam/crank sensors new 55 end codes
Old 10-21-2018, 10:23 AM
That code 11 could certainly be a problem....... Think that is something I would check first.
Turn the engine so number 1 is in firing position, and see where the rotor on the distributor is pointing.
Quick Reply: I need help serious cold start issues 318
