Engine shuts down no codes. Every electrical component has been replaced.
Old 11-19-2018, 04:10 PM
Steven Price's Avatar
Steven Price
Steven Price is offline
Default Engine shuts down no codes. Every electrical component has been replaced.
I have a 97 Dodge Dakota SLT 4x4.automatic transmission. Been having a problem with it shutting down for no apparent reason. It does not code & it takes 10 minutes to start back up. Every sensor & module has been replaced. Have lots of money tied up in this. I cannot recreate the issue. It does it whenever. Idling,driving.
Old 11-19-2018, 05:53 PM
Skreelink's Avatar
Skreelink
Skreelink is offline
Have you replaced the PCM? Mine was doing the same thing, no rhyme or reason. Turned out to be the internal connections of the PCM, common failure of the JTEC computers. Try starting the truck, then gently move the center connector up and down to see if it stutters or stalls. I chronicled my adventures with the same issue and the final resolution was here:
https://dodgeforum.com/forum/2nd-gen...ml#post3416155
The previous post was my temporary and this is more permanent until I get around to actually replacing the PCM (I don't want to until I replace the engine as well. 3.9 to 5.2)
Quick fix, try zip-tying the plugs down tight on the PCM, make sure they can't really move at all, also the two screws on the front, pull them out one at a time and put a nylon washer under it. The left one specifically I've read is right above the crank sensor input on the board, and due to age/temp causes it to warp slightly. The screw is a bit too long and shorts out on the board, causing the truck to die. It can either start right back up, or have to cool slightly to un-short. Putting washers under the screws, and a bracket to hold the connectors was my fix.
Old 11-19-2018, 07:53 PM
Steven Price
Thank you. Pcm has been replaced twice. All electrical components have been replaced. I will try washers. Thanks again.
Old 11-19-2018, 07:57 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Have you replaced the coil yet?
Old 11-19-2018, 08:46 PM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
There comes a point where it is cheaper to let the dealer diagnose the issue (then you fix), than to keep throwing parts at it.
Old 11-19-2018, 08:48 PM
Steven Price
yes I have. Thank you.
Old 11-19-2018, 08:50 PM
Steven Price
I agree. We only have 1 dodge dealer in my area & I don't trust them at all.
Old 11-19-2018, 10:04 PM
magnethead's Avatar
magnethead
magnethead is offline
Has fuel pump been replaced? I'd also be looking at the wiring harness.
Old 11-19-2018, 10:14 PM
Steven Price
Yes all electrical components have been replaced. I'm going three wiring harness now. Dont understant 10 minute delay though. Thank you.
Old 11-20-2018, 04:38 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Thumbs up
You need a tech like the owner of New Level Auto to test for your problem.
Not in your area but this guy is amazing at finding strange problems.
New Level Auto---------- https://www.youtube.com/user/ONBOARDTECH333KMD/videos
Quick Reply: Engine shuts down no codes. Every electrical component has been replaced.
