Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
1985 ram charger no spark.
Old 12-06-2018, 10:44 PM
Tanner Manno's Avatar
Tanner Manno
Tanner Manno is offline
Default 1985 ram charger no spark.
I have a 1985 ramcharger with a 318. 2wd. It needed a new starter so it sat for about 6 months. I put a new starter in it about a month ago. And now it has no spark. The truck ran great when I parked it last. It just needed a starter. And now that it has a new one. I can’t get it running. Where do I start? Really wanting to get it running again. Thanks.
Old 12-07-2018, 10:05 AM
lilredex's Avatar
lilredex
lilredex is offline
A few things you can check...
>put a test light on the coil to see if there is power (with key on)
>Remove the ECM and be sure its ground (under the mounting screws) is good.
> check to see that the ballast resistor is warm/hot with the key on for a few minutes
Both the B/R and ECM are shown in the picture... my '79 D100
Old 12-08-2018, 05:49 PM
Tanner Manno
Default .
Can you point out where the ecm is and where the ballast is? I don’t have a lot of knowledge of these older vehicles.
Old 12-09-2018, 08:47 AM
lilredex's Avatar
lilredex
lilredex is offline
In my picture the ballast resistor is that white block on the upper right. and the ECU/ECM is on the left diagonally. See the picture.
This is the normal ignition set up, but there are other configurations. You need to post a picture of what you have....
.so we know we are on the same page.
Old 12-09-2018, 11:52 AM
Tanner Manno
Default .
The balast is getting warm when the key is on.
Old 12-09-2018, 12:24 PM
HeyYou is online now
It's a resistor, it'll do that.
Old 12-09-2018, 12:59 PM
Tanner Manno
yeah I know. I was just letting him know because he said if it was working it would get warm.
Old 12-09-2018, 05:56 PM
Ok, that makes more sense then.
Quick Reply: 1985 ram charger no spark.
