Coolant Sensor Problems
Old 06-23-2019, 11:34 AM
Ray Wilson's Avatar
Ray Wilson
Ray Wilson is offline
Default Coolant Sensor Problems
I have a 1987 D150 with the 5.2L 318. I’ve been having problems with the temperature gauge. The gauge is always running low. Sometimes when I start the truck, the gauge will jump the mid-range (normal temp) then back down to almost nothing. I believe the gauge works, so I think the problem is with the coolant sensor.
I’m having problems selecting the correct sensor. When I select my truck on auto websites it shows me several different sensors. I attached a photo of my current sensor (at least what I think is the sensor! This is my first older vehicle I’m working on). If anyone could please help select the correct one I would appreciate it.
Old 06-23-2019, 11:42 AM
rebeltaz83's Avatar
rebeltaz83
rebeltaz83 is offline
Coolant sensor will have one wire, and I believe it's on the other side of the upper radiator hose.
Old 06-23-2019, 11:44 AM
Ray Wilson's Avatar
Ray Wilson
There is nothing on the other side of the radiator hose. This is the only sensor I could locate. I replaced the thermostat a few months ago and did not see anything on the other side when I removed it.
Old 06-23-2019, 12:14 PM
rebeltaz83's Avatar
rebeltaz83
They look like vacuum lines. How long have you owned the truck? I wonder if the PO didn't pull the sensor and plug the hole.
This is the sensor with the wire attached.
This is what the plug in looks like, and the sensor not plugged in.
Old 06-23-2019, 12:25 PM
Ray Wilson's Avatar
Ray Wilson
That helps a lot. Then what did I take a picture of? I will check when I get back to my truck. My Haynes manual had the sensor in a different spot completely so I’m all confused.
Old 06-23-2019, 12:31 PM
Ray Wilson's Avatar
Ray Wilson
So I identified the problem.... I couldn’t see the sensor because there is no sensor. There’s just a hole. I located two loose wires that look like they were cut near where the sensor should be.
Old 06-23-2019, 12:50 PM
rebeltaz83's Avatar
rebeltaz83
I wouldn't think it would have 2 wire sensor but maybe. I'd try to see what the wires go to. The coolant sensor wire should move the needle if it's grounded.
Is the sensor broke off?? It should be leaking coolant if it's just an open hole.
Your truck doesn't happen to have the lean burn system does it?? Big black box with wires on the side of the air cleaner.
Old 06-23-2019, 02:08 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
that is smog related stuff that you took a picture of. the coolant temp sensor should be right need the heater hose on the intake. 1 wire. the gauge one is always there unless you have an aftermarket intake. the computers one is usually on the drivers side by the upper rad hose.
Old 06-23-2019, 11:07 PM
Ray Wilson's Avatar
Ray Wilson
Upon further inspection I do not believe the sensor is missing. I checked earlier quickly at work, but I believe I was wrong. Here are pictures of what I found under the hood. I still believe my original photo is of the sensor.
Old 06-24-2019, 08:13 AM
That's a vacuum switch, not a sensor.
Quick Reply: Coolant Sensor Problems
