ABS & Brake lights on
Old 07-21-2019, 04:47 PM
kc2llw's Avatar
kc2llw
kc2llw is offline
Default ABS & Brake lights on
Hello,
I am working on a 2000 Ram 1500 sport 4wd quad cab rear abs. Came to me with a leaking frame brake line and ABS light on. I have replaced all the brake lines with NICU lines, all hoses and Master cylinder also replaced rear wheel cylinders and front calipers. I also replaced the ABS sensor in the rear axle. When I received the vehicle it showed codes 36 no signal from the rear sensor and 72 ROM Checksum. After doing all the work and resetting the DTC's I am now getting the abs and brake light on after about 3 or 4 times applying the brakes. After shutting the truck off and back on again the lights are off again until the brakes are applied 3 or 4 times again. I have scanned the truck and it shows no codes present. Any help would be appreciated.
Thanks,
Steve
Old 07-21-2019, 04:50 PM
Spillage's Avatar
Spillage
Spillage is offline
For me, that was the speed sensor on the rear axle.
Old 07-21-2019, 04:57 PM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
check that you are getting good fluid flow to the rear brakes (bleed it, should move fluid really well).
Old 07-21-2019, 05:13 PM
kc2llw's Avatar
kc2llw
kc2llw is offline
I bled it using a vacuum bleeder first. Then I rebled it by the manual brake pedal way seemed to push the fluid out decent. do you think this could be the problem?
Old 07-21-2019, 08:40 PM
May be the proportioning valve just isn't *quite* in the right spot. Grab a friend, bleed all four corners again. Take it out, find a dirt road, STOMP on the brakes. (make the abs do its thing. lites have to be off for it to play nice.) Re-bleed the brakes. Should be golden. (hopefully)
Old 07-21-2019, 09:15 PM
kc2llw's Avatar
kc2llw
kc2llw is offline
I did notice the line from the front port of the MC to the PV which feeds the rear brakes has a sharp bend that is close to almost a kink looking bend I wonder if this could be the issue
Old 07-21-2019, 09:32 PM
Entirely possible. If flow is restricted too much, it will displace the proportioning valve, and turn on the brake lite, which in turn, turns on the ABS lite.
Old 07-21-2019, 10:16 PM
kc2llw's Avatar
kc2llw
kc2llw is offline
I will check it out tomorrow. I will replace it and rebleed. I will try to get a picture of the over bent line too. hopefully, this will fix it.
Old 07-22-2019, 09:35 AM
kc2llw's Avatar
kc2llw
kc2llw is offline
Here is a picture of the bend the picture makes it look less kinked.
Old 07-22-2019, 11:22 AM
is that a stock line, or has it been replaced? When bent right, the lines shouldn't do that kind of thing......
Quick Reply: ABS & Brake lights on
