Getting obd 22 code - Engine coolant temp sensor out of range
Old Jan 19, 2020 | 02:42 PM
rrb6699's Avatar
rrb6699
Default Getting obd 22 code - Engine coolant temp sensor out of range
Obd 22 is shown for my 1996 dodge ram. mfr date 3/96 so it maybe they switched to obdii later that year.
22 Engine coolant temp sensor out of range is all can find on this code
throws no other codes. when truck is hot I either I cant start it or it takes a lot of cranking then it barely starts.
not sure if it's related. any ideas?
Old Jan 19, 2020 | 03:10 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sensor is probably bad
Old Jan 19, 2020 | 05:04 PM
DerTruck's Avatar
DerTruck
See page 14-53 in the service manual for a table of what the coolant sensor resistance should read at different temperatures. Best way to check the sensor.
Also check that there is no short to ground from any of the terminals.
Old Jan 20, 2020 | 07:46 PM
2bit's Avatar
2bit
There are 2 coolant sensors. The one for the PCM has 2 wires I think.
Old Jan 20, 2020 | 07:52 PM
rrb6699's Avatar
rrb6699
Default both sen
both sensors are new
both temp sensors are new
just replaced them. then I got the code. I hear air hissing sound (fairly loud when I try to start. it does start but takes several seconds of cranking. it might stall as I hear the hissing while it's trying to run. then the hissing stops and the truck can be driven. when it is at op temperature it will not start again until it cools off some.
someone told me it's a head gasket. I disagreed and said it would never run right while driving.
is this the stepper motor? see attached.
Old Jan 20, 2020 | 10:06 PM
MoparFanatic21
That is it! You might want to try and pin point where the sound is coming from. Have someone in the truck and you try to see exactly where it's coming from. Also try to keep it in the same thread as it gets confusing answering two different threads
Old Jan 20, 2020 | 11:52 PM
rrb6699's Avatar
rrb6699
That is it! You might want to try and pin point where the sound is coming from. Have someone in the truck and you try to see exactly where it's coming from............
I was thinking if it's intake, couldn't I spray starting fluid towards the Hiss and if I find it wouldn't the engine rpms increase?
Old Jan 21, 2020 | 12:51 AM
DerTruck's Avatar
DerTruck
Yes that works. Carb cleaner and brake cleaner are also popular. Anything that's flammable
Old Jan 21, 2020 | 01:32 AM
MoparFanatic21
I had luck and no luck with that. Someone's the computer can compensate quickly enough that the RPMs don't go up, sometimes they do. Had a vacuum leak on my 01 360 and my 07 Hemi neither would rev. It was a substantial vacuum leak. Give it a shot though and see what happens.
Old Jan 21, 2020 | 09:48 AM
If you are getting temp sensor codes, need to have a good look at those. Plugging in a scanner, to see what the PCM thinks temps are at, is a good idea.
Cleaning the throttle body wouldn't be a bad plan either.
