4.7 interference engine???
So I can get this 03 ram 1500 2wd with the 4.7. The guy said it started bogging down on him while driving one day and started out to be just an occasional thing. Then it got to be an every day thing and he took it to his mechanic who said something about the timing guides and that the 4.7 is a piece of crap and refused to fix it. So the guy bought something else and is willing to sell this to me really cheap. What do you guys think could be the problem? And if it is an interference engine, what are the chances of it being ok if it's just got worn out guides?
Not sure if the check engine light is on or not. I've only seen the front end of the truck from his driveway while I was picking up a lawnmower from him. I wasn't really interested in the truck at the time but I asked him to start it and let me hear it and it started right up without hesitation and idled just fine for about 10 minutes. It did sound like it had a miss but it was barely noticeable. The truck is in great condition inside and out and it's a quad cab so for the price I'm going to buy it from him regardless of the engine issue. I'm just trying to get an idea of stuff I could check before I jump straight into replacing stuff. For the price of the truck, even if I end up replacing the engine, it will still be cheaper than any other quad cab truck posted for sale running or not.
The pistons have the ability to meet the valves, so they certainly are interference engines. I did valve stem seals/lifters almost a year ago and could support the valves with the pistons in TDC, so they wouldn't fall in. They are very sturdy if taken care of in the simplest manner (good oil and coolant).... mine has 320K mi. and still running like a top.
Jadwin311 (Today)
It's possible it could have jumped a tooth, but bogging could be a lot of things, like JKeaton said. I would check all the easy/cheap stuff first, starting with any codes it might be spitting out. Bad plugs, dirty throttle body, transmission issues, vacuum leaks, badly clogged air filter (computer will adjust for this, but can only do so much), weak fuel pump, clogged injectors...I could go on. I'd start with codes, plugs and throttle body. Check Tranny fluid....
I've had bogging at highway speeds randomly when the Ram gets warmed up, and rough idling sometimes as well. Changed the throttle position sensor (TPS) last Thursday, around $100 part, and now its running smooth.(There were no codes except for the downstream O2 sensor and that's been on for the last year).
I'd do a good cleaning of the throttle body and Idle air control valve as well.
