Differential fluid
Differential fluid
I changed the differential fluid after hearing a tad of a whine..Is this a sign of contamination or water or what?
It a 01 3.9 2wd automatic..
An is the torque 30 ftlb on cover? i did 27 but I dont think that will factor
It has that off tan look..Any additional info is appreciated.
Usually, there is a vent tube that holds the junction block for the rear brake lines to the axle. Should have a hose going to it, that just goes up and ends somewhere near the frame, with a plastic cap on it. (that is supposed to keep it from sucking in water.... doesn't always work. )
