Joe, Take a look under the hood in the relay box. I had the same problem on my Durango and it was one of the 5 prong relays. When the get old sometimes they'll get sticky or refuse to work. Just a suggestion because it fixed my problem.
What I did at first was just switch them out to see if it solved the issue, When it did I went to Amazon and bought a few of these and replaced the one bad one. They are cheap so due to age you might just replace all of them.
