Guad headlights problem
Old Today, 07:31 AM
0koudy's Avatar
0koudy
0koudy is offline
Default Guad headlights problem
Hello everyone i have question in my Sport quad lights should all 4 headlights bulbs shine when i turn on high beams ?
Because my dont do that . Where should i look. Thank you all in advance.
Old Today, 08:45 AM
Received 3,294 Likes on 3,041 Posts
Nope. Low beams will turn off when high beams are on.
Old Today, 08:51 AM
0koudy's Avatar
0koudy
0koudy is offline
Ou and low beam should be outer bulb or inner one ?
I saw them in both spaces so i dont know what is factory
Old Today, 08:52 AM
I believe the outers are low beams.
Old Today, 08:56 AM
0koudy's Avatar
0koudy
0koudy is offline
Ok so that have right .
Suprised that all 4 dont shine with high beams because its like driving with candels
Old Today, 09:02 AM
Are your headlights really yellowed? Aimed properly? On both my 2nd gens, (neither had the quad headlamps) the headlights absolutely SUCKED. I bought new bulbs, new housings, and the heavy duty relay harness for them, and life was good. The headlight switch in these trucks were marginal to begin with, and there are many horror stories of the switch getting hot, and melting things, if not burning the truck to the ground. Even worse if you have the clearance lamps on the roof.....
Old Today, 09:19 AM
0koudy's Avatar
0koudy
0koudy is offline
Well i have new headlights and new led bulbs .
And i have quad headlights from factory .
And i got them aimed
Old Today, 09:34 AM
Add the heavy duty harness. What it does is, feeds power to the bulbs directly from the battery via relays, takes the load off the switch, and gives better light.
Old Today, 09:38 AM
0koudy's Avatar
0koudy
0koudy is offline
Ok thank you i will try to look for that
Quick Reply: Guad headlights problem
