Scan Tool
Scan Tool
I am hoping someone can recommend a decent scan/diagnostic tool for a 2000 Gasser. It seems the options are very very limited.
I have purchased a MT2500 - had to sell it because it is hit or miss with the software and cartridge compatibility, and the fact that Snap-On no longer supports it make it a black hole of trying to find a MT2500 and compatible cartridges.
AlfaOBD only shows support back to 2004.
Most other scan tools only provide basic options.
i am looking for a scan tool that can set fuel sync and perform other functions than just the bare minimum.
All I have been able to find is the Innova 5610.
I actually purchased one from a retiring mechanic and the software “updates” performed on the cartridges/MT2500 left the MT2500 unable to connect to my vehicle. I have a local Snap-On guy that I talked to about it and he said I may have to try numerous Chrysler keys to get it to work or buy different cartridges. It’s just a black hole of finding the right stuff.
Best to find the Chrysler specific MT2500 primary cartridge that covers your year truck to use with the "red brick" MT2500 scanner - here's an example - https://www.ebay.com/itm/225811655140 - when I use that specific cartridge with my truck, in my experience, it usually doesn't ask me for a personality key.
Generally older "pro level" tools tend to work well with pre-canbus vehicles. Older snap-on scanners need the stupid personality keys and sometimes newer software needs different newer keys but work good. The OTC genisys with the smart cable (not the older snap-on style cable with keys) works very well from personal experience. Then there's the DRBIII but they seem to command a hefty premium. There's also a DRBIII emulator SW but getting this to work seems pretty involved.
The tricky part is that the OBD2 connector in the 2nd gen connects to three different buses, the mandatory OBD2, the CCD and the SCI bus. Hence the need for smart cables or personality keys, and the reason most newer tools can only get basic information from the PCM and don't talk to ABS or airbag modules.
One is the OTC Genesys Touch and the other is OTC Genesys SPX
The Genisys SPX is what I have. Most of them have dead batteries by now but it's a dirt cheap RC car battery, and they work without battery anyways. No experience with the touch but it appears to have OBD1 adapters for Chrysler so it can talk CCD bus.
In any case make sure it has properly activated software on it. The tool alone is useless.
In the scan diagnostics menu there is a lock symbol next to feature packages that are not activated. Ideally Domestic, Asian, European, Airbag/ABS and Generic OBD2 would be unlocked but you could do without Asian and European. You don't need the Latin America models or the Heavy Duty trucks and most customers didn't buy these.
At least as of version 3.0 there is a demo mode where the tool generates random live data or if you can get your hands on it the Generic OBD2 should work on pretty much anything, even much newer vehicles.
Another thing to look for are the OBD1 adapters. They are not needed for a 2000 but are handy if you ever want to work on something pre 1996.
