318 magnum to 360stroker -408 swap
Old 08-05-2024, 12:38 AM
dodgeman2001's Avatar
dodgeman2001
dodgeman2001 is offline
Default 318 magnum to 360stroker -408 swap
has anyone swapped a single cab shortbed 318 magnum to a 360 based 408? if so it would be beneficial to see a parts chart with prices to get some ideas going. just wondering if it has been done and if it is worth it or not. Thanks in advance
what i’ve read is just about the internal and external balances. nothing to helpful about a complete swap. would like to keep oem electronics but open to any ideas.
Old 08-05-2024, 07:52 AM
Received 3,302 Likes on 3,047 Posts
Many folks have dropped the stroked 360 into their truck, cab configuration isn't relevant. Is it worth it? That depends on what you have in mind. If your truck is 95 or older, stock electronics simply won't work. 96 and newer would require a custom tune. The stock kegger manifold is going to choke a 408 above about 3500 RPM..... best to use something better.... trouble is, not a lot of choices there, if you want to stay with MPFI.... Figure on spending in the neighborhood of 5 to 7K to get it together, and running...... Probably more.
The following 2 users liked this post by HeyYou:
dodgeman2001 (08-05-2024), jkeaton (08-05-2024)
Old 08-05-2024, 12:12 PM
dodgeman2001
It is an 01. I’m just trying to get some ideas going. I’ve tossed around the idea of a 440 but think it’s too much head ache rather than just dropping in a stroked 360.
Old 08-05-2024, 12:42 PM
PR1AWRet's Avatar
PR1AWRet
PR1AWRet is offline
440 with a Holly Terminator (for example) and a 46RH transmission seems a lot less hassle to hook up than the 408. Get a 68/69/70 440. The newer 77/78/79 440 were 100hp less than the late 60's.
Old 08-05-2024, 12:43 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
There are several past threads that discuss things that were done to install a 408 into these trucks. There was one member that provided details about his combo, as I recall..
You should be able to find them using the forum's search feature..
Old 08-05-2024, 12:56 PM
dodgeman2001
I’m not to familiar with this forum so I’m still figuring it out. I’ll look into finding it. I’m just trying to find a good solution to some hp because the 318 just doesn’t make enough.
Old 08-05-2024, 12:57 PM
dodgeman2001
And with this I will be able to keep oem electronics ?
Old 08-05-2024, 12:59 PM
AtomicDog's Avatar
AtomicDog
Post
Not to my knowledge..
Old 08-05-2024, 02:28 PM
PR1AWRet's Avatar
PR1AWRet
PR1AWRet is offline
Nope it isn't.
Old 08-05-2024, 03:33 PM
No. Being an 01 complicates matters.... (actually, being a 98 or newer.....) All the gauges are told what to display by the computer via the communications bus. Right down to the gas gauge..... What is the end goal here? What do you plan to use your truck for?
Quick Reply: 318 magnum to 360stroker -408 swap
