Plenum Gasket - Ram Van 5.9
To anyone familiar with the plenum gasket repair (The Hughes Kit) on these... What else should I replace/repair/inspect/clean while in there?
Water Pump
Timing Chain Set
Thermostat
Hoses
What else? Plugs, wires, cap&rotor are pretty new, although I installed platinum plugs, which I've since read are not a good idea with these engines, so will probably replace those.
Thanks in advance for any shared wisdom/experience.
Water Pump
Timing Chain Set
Thermostat
Hoses
1998DodgeRamVanCamper (08-19-2024)
My dad had a Superbee which the metal pan on the 727 would just always leak, no matter how hard we tried. Since then, I have a phobia about mopar gaskets leaking when bolted down under stamped steel.
However, I think you have just made me give thought to how expensive that kit really is and so I think I'll buy an ebay cheepie and put together the collection of other gaskets and bolts, myself.
Thanks for the advice!
I like hughes and what they offer for these motors but the kit is expensive for what it is. I've always bought ebay kits, never had an issue, they usually come with bolts and a gasket, though I opt to swap it for a known fel pro, mahle, whatever the local parts store happens to have on hand that particular day, just to make sure its of suitable quality.
1998DodgeRamVanCamper (08-20-2024)
Hughes charges a premium price for their kits, and I didn't like the gaskets that came with it..... Bought a Fel-Pro set. Intake was still clean six years later. (Mopar PCV valve as well.... they are actually the correct flow rate...)
I think I've read hundres of pages about the magnum plenum, the "end-all be-all plenum thread", the "post your plenum gasket pictures" thread, etc.
All info there pertains to trucks.
I hate that I have to ask this because I feel like the plenum topic horse has been beaten to death, but it's super frustrating that there's next to nothing on youtube or even in this forum about doing the plenum gasket repair on Ram VAN.
Anyways... My question: Is there anything fundamentally different about doing this job on a van? Is there anything that I do/don't have to remove that would differ from the truck instructions? There's no VAN-specific write up for this anywhere, is there?
Thanks for any input!
