HID Special $60.00 Shipped for Dodgeforum members
Old Jan 18, 2010 | 05:42 PM
  #401
hidextra.com's Avatar
hidextra.com
Former Vendor
VALENTINE SPECIAL!!!
Why not buy an HID kit for your GF, Wife, BF or Husband so they can see better at night and for their safety!
COUPON CODE: valentine2010 ($18 off online price)
EXPIRATION: Feb 16, 2010 Midnight PST
So the special price is $57 per kit, for those of you who were thinking of purchasing more than one kit, you'll save yourself some money! Thanks!!!!!
Instructions:
1.) Go to this link to check on bulb type
http://www.sylvania.com/ConsumerProd...lacementGuide/
2.) Then go to www.hidextra.com and choose the (BULB TYPE AND COLOR)
3.) Use Express checkout
4.) Input coupon code: valentine2010-m to get $18 off the kit price
5.) IF you are purchasing more than one kit, please do SEPARATE transactions for EACH kit in order to get discount on all kits.
Any questions, please email me @ info@hidextra.com
HAPPY VALENTINES To ALL!
Michelle
Old Jan 19, 2010 | 10:08 PM
  #402
Stihlpro's Avatar
Stihlpro
Recieved my HIDextra kit today. Purchased the H13 6000K Bi-Xenon kit. I installed it tonight and it doesnt seem much brighter than stock. It is bright, but not like other pictures I have seen. I have a few questions as the install directions weren't helpfull. When you take the protective caps off the HID lights do you leave that foam ring on for a seal or do you remove it before installing bulb in housing? I tried to install with it in place but couldnt get the bulb to lock in. It was getting dark and I just installed them without for now. My stock lights seemed like they were pointed too low from factory and installing these lights still doesnt give me much more distance than the stock bulbs did. Does it have something to do with the bulb guard that is stock inside the housing? BTW, I don't have fogs. Also, whille i was driving I flipped on the high beams and the was a loud humming noise. I suppose it is from the ballasts. But should it hum like that? When I turned off the high beams it stopped and went back to normal, But after 3 seconds I would get a quick flash as if I flashed the high beams manually. I think everything is hooked up ok. Does anyone have a wiring diagram or a step by step that they have done on their 09? It would really help. I included a pic of what my lights look like on low beam.
Attached Thumbnails HID Special .00 Shipped for Dodgeforum members-securedownload.jpg   HID Special .00 Shipped for Dodgeforum members-securedownloads.jpg   HID Special .00 Shipped for Dodgeforum members-securedownloadsss.jpg
Old Jan 20, 2010 | 03:05 PM
  #403
hidextra.com
Former Vendor
HI,
I believe all questions has been answered per phone call, thanks!!
Michelle
Old Jan 20, 2010 | 03:07 PM
  #404
hidextra.com
Former Vendor
Shipping Reminder:
All orders placed before 3pm PST yesterday have been shipped.
All Kits are shipped Priority mail 3-4 business days (give or take 1-2 days due to holiday delays)
All bulbs and accessories (non kit orders) are shipped First Class Mail which takes about 4-7 business days (give or take 1-2 days due to holiday delays)
Thank you for all your support and patience!
Michelle
Old Jan 20, 2010 | 08:19 PM
  #405
Stihlpro's Avatar
Stihlpro
Originally Posted by hidextra.com
HI,
Michelle
Yes, All questions were answered. I also used the search function and came up with the reason why my lights stock/aftermarket didnt shine more than 20' in front of me. The reason is because the factory has the housings aimed very low. 5 turns on the adjustment nut on each brought them up right where they should be. now the lights are SWEET! I took her out on the open road with socket in hand to see if I was going to get flashed by other cars. If I did I would just take a half turn off each time. But after driving dark roads, Highways, And through town streets for 45 minutes not one car flashed me from being blinded.
Old Jan 20, 2010 | 08:47 PM
  #406
jason2922's Avatar
jason2922
Originally Posted by ran jr
So a relay with a direct connection to the battery will cure the interference issues? The kits are advertised as 35 watts and need a resistor to increase the consumption up to the standard 55 that the PCM looks for.
Sorry ran jr. I have no idea about the REN High Bus system, I just know that the ppl that are having problems are with that type of system. HID's in general should not cause any type of interference, they don't transmit a signal to block out FM/AM. What ppl are saying on here is that they have a total loss of stations. This has to do with the electrical system doing some crazy stuff, feedback or improper voltage to run the stereo due to a slight drain on inconsistant voltage due to the HIDs. I'm sure dodge know's about it. But a relay or capacitor will not fix radio interference, two different beasts. Right now, the relays and capacitors are designed to make the HIDs operate correctly. Not to ensure your REN is receiving proper voltage to operate correctly. If you had a stock stereo, I'm sure it would work just fine. There's other treads of ppl saying their REN works some days and others it's a pain and etc.
Old Jan 21, 2010 | 03:17 PM
  #407
hidextra.com
Former Vendor
So glad everything worked out for you, thanks for the feedback!!!
MIchelle
Old Jan 21, 2010 | 03:23 PM
  #408
hidextra.com
Former Vendor
Instructions:
Michelle
Old Jan 21, 2010 | 05:12 PM
  #409
hidextra.com
Former Vendor
Hi all!!
I just had one of my customer wrap foil around their ballast and the interference went away, so for those of you who are having radio interference, try wrapping the ballast with tin foil and it should decrease the interference. Thanks~
Michelle
Old Jan 21, 2010 | 10:28 PM
  #410
Huff360's Avatar
Huff360
Originally Posted by Huff360
Somone with the problem could try shielding the ballast and the wires going from the ballast to the bulbs as much as possible.
An easy way to test shielding and see if it would help is as follows:
Wrap the ballast and the bulb wires with a few layers of Aluminum Foil (Reynolds Wrap or something like it).
Holy crap! You mean somebody listened to me and it worked??
Crap. Guess I should have gotten my how to put together earlier.
