just bought a 05 neon sxt
Mileage? Do what I Did. Replaced every leaky seal and new timing tensioner/ belt / water pump. Replace hole rear end. Struts brakes lines springs shoes drums cylinders. Rotors pads re seat spark plug tubes. Intake exhuast gaskets. Coolant thermostat both radiator hoses. Both heater hoses.
Much more.
That way there is no service needed for a long time. Just oil changes.
Much more.
-Definitely get the timing belt/water pump/belt tensioner changed as recommended. Also have the tie rods and lower ball joints checked. Just remember. They call it "preventative" maintenance for a reason. You don't want those valves kissing the pistons if the belt goes out. I bought my '05 SXT in '07 with a bit over 19k on it. It has around 139k on it right now and still runs like a top. No fluid drips on the garage floor, and no blue smoke from the exhaust. I'd drive this car from Ohio to Alaska without any hesitation...
L8R,
Matt
L8R,
Matt
Trending Topics
