Would you recommend all these "kits" for my plenum repair?
Gonna dive into the plenum fix on my 2000 Sport. Since I am going to have it apart I figure I should fix what I can, but is it really worth all of these "kits" or is Hughes just trying to sell some more hardware?
http://www.hughesengines.com/Index/p...z&partid=22220
http://www.hughesengines.com/Index/p...5&partid=23039
http://www.hughesengines.com/Index/p...8&partid=24032
You do not need the 3rd kit. At NAPA new Belden wires, Echlin cap and rotor, and eight NGK V-power Spark Plugs would cost you $67.
You can get a FEL-Pro intake manifold gasket set at AutoZone for $22. Bolts at my dealer were $17. The plenum gasket at my Dealer was $16. New plenum plate bolts were $10.
I made my own plate with a Jigsaw and scrap aluminum for $26.
Ok, thanks Purpl. I will go that route then. I want to do it right but not spend more money than I have to. Is there a place where I can get just the plenum plate by itself, one you would recommend instead of making it myself? The idea of making one is cool but I don't want to go to that extreme.
I might start making them in a few years, I need a CNC mill....
Trending Topics
Huh? The plenum gasket I got at the dealer was $2 more than the ****-Pro (FEL-Pro) I bought at AutoZone. The FEL-Pro is the same design that was put on at the factory. The Mopar one is a improved metal compression gasket. APS includes it in their kit along with new Mopar plenum plate bolts.
This one for $84.
"These plates are precision laser cut 6061 Billet Aluminum 1/4" plates. The kit comes complete with the improved Mopar plenum gasket, Grade-8 Flange Head bolts, 1 bottle of lock-tite, and complete instructions. These plates will *******ly eliminate the common problem of leaking due to heat properties of the factory steel plate and can stand up to 12-15# boost and/or Nitrous Oxide without any issue"
BILPLEN-V8 Billet Plenum Plate Kit - 1992-2002 Dodge Magnum V8 (5.2/5.9L)
I will get the wires and cap and plugs from NAPA and then get the intake gaskets and bolts from the dealership, is that cool? I am on the right track right?
Then all you need is the intake gaskets and bolts.
Gaskets:
http://www.napaonline.com/Search/Det...+50022+2022009
And the Mopar TTY intake manifold bolts:
6035967AA Intake Manifold bolts - $17.28
Gaskets:
