Please help me .... Antifreeze leak coming from transmission housing???
Old 02-06-2011, 01:25 PM
bduals420's Avatar
bduals420
bduals420 is offline
Default Please help me .... Antifreeze leak coming from transmission housing???
Hi I have a problem and have been searching for it but no luck so maybe sombody can help me....
Leaks only antifreeze from possibly the tranny...
Its after the engine before trans...Cant see if the freeze plugs good or bad..
But it drips from inside the housing....but its not spray off ..it is deff coming from inside somthing out to the bottom trans seal ...
I bypassed the heatrer core ...still leaks
I dont know what it is it heats up to proballly 220 ish then then drops to 190 ish operating temp...I dont no what to do.. I dont really have cash to just replace all the parts until its solved.. Just rebuilt the whole front end with hd parts...
followed all coolant lines...
all my fluids are there own colors....
i do have pin hole trans cooler line leak ...
Any body have any help im all ears thanks
Old 02-06-2011, 01:49 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
if you're sure its not coming from the water pump or intake, or side-of-block freeze plugs, its probably coming from the back-of-block freeze plugs. the correct fix is to remove the transmission and replace them.
however, you might be able to seal them up with a stop leak product. i always get flamed for suggesting this, but it doesn't really hurt anything and sometimes it works.
as far as overheating a little, its probably due to low coolant. keep the radiator and overflow tank full. be careful about opening the radiator cap.... don't get burned.
Old 02-06-2011, 01:51 PM
Gary C.'s Avatar
Gary C.
Gary C. is offline
My guess is a freeze plug.
Old 02-06-2011, 02:27 PM
dhvaughan's Avatar
dhvaughan
this might be helpful
https://dodgeforum.com/forum/2nd-gen...e-clarify.html
Old 02-06-2011, 04:07 PM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
Nice picture
Old 02-06-2011, 07:57 PM
bduals420's Avatar
bduals420
Pics of my daughter three days old .. Logged on with face book... Thanks dhvaughn, I wasnt sure, ..my leaks coming from the bell housing , any idea on labor totals to do this
Old 02-07-2011, 08:57 PM
DodgeRam10's Avatar
DodgeRam10
DodgeRam10 is offline
its definitley your rear freeze plug just had the same problem a couple months ago. most shops i called wanted about $450 to pull tranny,replace freeze plugs and put tranny back up. i found a shop that did it for $300 out the door. I was going to do it myself to save $297 but i didnt have time and needed my truck right away. this should give u a ball park estimate of shop prices.
Old 02-08-2011, 07:14 PM
bduals420's Avatar
bduals420
Thanku all my quotes are at seven hundred and up... Doing it myself...
Old 01-25-2015, 09:46 PM
cfd22's Avatar
cfd22
cfd22 is offline
Default 2008 Dodge Avenger V6
antifreeze leaking from what I assume is a bolt hole in bell housing
Old 01-25-2015, 11:48 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Dripping off the bottom of the trans near the inspection plate? Or running down the outside of it?
Quick Reply: Please help me .... Antifreeze leak coming from transmission housing???
