spongy brakes
spongy brakes
I bought a 97 ram 2500 4/4 for cheap. I had good brake peddle it just pulled to the right bad. I replaced the calibers had the rotors turned new brakes. I have bleed the brakes several times and I still have a spongy brake. I have done a lot of brakes so i know there bleed right. I have adjusted the back brakes up. I see no leaks. when i pinch of the rubber hoses to front calibers i get good brake peddle. So my thinking it has to be calibers. Is there something I'm missing I'm lost any advise would be helpful. One more thing is i have good peddle with the truck not running.
Bleeders are up on top, right? (highest point on the caliper.)
Probably just still have a bit of air in there. Have a friend help you bleed. Pump up the brake pedal, hold the pressure, then crack open the bleeder. (yes, it shoots fluid, be careful.) That should shock any air loose.
May want to have a look at the brake line going to the rear as well. It is notorious for rusting out, and breaking, above the gas tank......
