Hughes Vs E-bay
Old 09-15-2015, 09:28 PM
Monroe00ES's Avatar
Monroe00ES
Monroe00ES is offline
Default Hughes Vs E-bay
So while I've noticed many people here have the Hughes plenum pan, I started to look for alternatives and found this:
http://m.ebay.com/itm/DODGE-ALUMINUM-PLENUM-GASKET-REPAIR-PLATE-1992-2003-5-2L-5-9L-/141773201228?nav=SEARCH
I searched the forum and found that someone here at one point was selling laser cut plates, but this one is waterjet cut.
Does anyone have experience with this plate?
Old 09-15-2015, 09:43 PM
jsmith1969's Avatar
jsmith1969
jsmith1969 is offline
That's the seller I bought mine from when I did the plenum, plate fit great and seemed well made.
Old 09-16-2015, 10:21 AM
schmidtp's Avatar
schmidtp
schmidtp is offline
As long as its an aluminum plate and you torque it down correctly I am sure it will be fine.
Pick up the Fel-Pro gasket while you are at it.
Old 09-16-2015, 10:38 AM
Moparite's Avatar
Moparite
Moparite is offline
You can make your own out of a piece of aluminum if you have the time. It's not rocket science.
Old 09-16-2015, 01:04 PM
Monroe00ES's Avatar
Monroe00ES
Unfortunately, time isn't something I have an abundance of...
Fel-pro gasket set @ local auto parts store - $22
Bypass hose @ local parts store - $7
E-bay plate - $75
New plenum pan bolts @ local dealer - $18
New intake bolts @ local dealer - $21
Total - $143 so only slightly cheaper than buying from Hughes.
Though, It appears I will be missing the bottom left gasket in this picture..
http://www.hughesengines.com/Tools/P...title=HUG7720R
What is that gasket?
Does anyone know if the plenum pan bolts are TTY?
Wonder if replacing those is just a waste of money...
Old 09-16-2015, 01:08 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Gasket in question is throttle body gasket. (between tb and intake)
Pan bolts are re-usable. Make sure to use some blue loc-tite on 'em though.
Supposedly, the intake bolts aren't torque to yield either, but, I REALLY don't recommend trying to re-use them.
Old 09-16-2015, 01:59 PM
Monroe00ES's Avatar
Monroe00ES
The dealership I just spoke to told me the intake bolts are TTY... figures they would say that to just make a sale. But I'm for replacing them either way.
Throttle body gasket brings my total up to $145 so still not bad.
Is there a major difference between the Mopar Performance intake bolts and the oem bolts?
The MP bolts are actually cheaper(Slightly with shipping), but then I have to wait for them to be shipped here.
Old 09-16-2015, 02:10 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
1997JollyGreenGiant is offline
My aluminum plate came from a seller on eBay. I've been happy with it. Mine came with new bolts though...
Old 09-16-2015, 02:14 PM
Performance bolts? Really? Wonder how many horsepower they add.
intake bolts are intake bolts. I don't think the stock fellers are torque to yield, the service manual says NOTHING about re-using them, or not. They ARE cheap pot-metal though..... so, replacing them is certainly a good idea.
Old 09-16-2015, 02:40 PM
schmidtp's Avatar
schmidtp
schmidtp is offline
If you are not in a hurry to get this done I would try to see how much it would cost you off RockAuto to order the parts, that is what I did
Quick Reply: Hughes Vs E-bay
