Can the No Bus code in odometer mean anything other than failing PCM?
No bus indicates the cluster isn't getting information from the central timer module. It's acts as the hub for the system. (as in, networking) So, might be the PCM, might be the CTM...... I am not sure of any real way to diagnose which is the failing component, short of replacing one, or the other, and see if the problem goes away. Given that the truck simply dies, and then the message pops up, that would tend to indicate PCM failure though.....
CTM does all sorts of stuff. Good description for it in the service manual. So far as I know though, no relays directly involved there.
One of it's main jobs though, is it acts as a network hub, between the PCM, cluster, and diagnostic port. Just like a hub on a computer network. But, even if it failed, the engine would still run, just the cluster wouldn't have any idea what was going on. The engine quitting does tend to indicate a PCM problem.
I think CMCKenna had a good post for troubleshooting No Bus errors.... of course, it's a few years old now, but, it should still be findable.
The thing is i live in southern CA. its all heavily populated city so i cant just go drive around anywhere until it does it again without putting myself and others in danger. God for bid it died on my on the dreaded 405. I would get shot for making people even later.
Seriously though, I would try the PCM first. If it is going then it could cause other systems to act flaky.
Another left field thought, how old is your battery?
Trending Topics
brand new optima red top. only a year old
