Dana 60 crush sleeve
I'm currently regearing Dana 60, which I intend to install on the front of my truck.
Axle is from 1999 Ram 2500 HD. Came with 3.55 gears
I got limited slip for it and 4.88 gears.
I just found that 4.88 pinion is machined little differently than stock 3.55 was.
There is no room on the pinion to install crush sleeve.
Do I just forget crush sleeve or try to find shims in its place ?
Hmmmm, how important is crush sleeve anyways?
They are USA Gears brand
It looks like there is Dana 60s with and without crush sleeve.
Depends on design.
Ones without crush sleeve use shims/spacers.
Shims it is. Just have to get the right height to get right preload
I'll probably have to put it together and take apart few times before its right.
Depends on design.
Trending Topics
