?'s About Timing Chain
Old 02-20-2016, 07:19 PM
mattk's Avatar
mattk
mattk is offline
Default ?'s About Timing Chain
Ok so my 2001 Dodge Ram 1500 4x4 with the 360 motor is due for a plenum fix. I am at 136,xxx miles. Been putting it off, but I think it is time for me to get in there and get it done. I figure while I am at it I am going to do the water pump, and timing chain. I have a slight coolant leak at the timing chain cover anyway. So my question is which timing chain set to go with? I have done a search on here and figure I am going with a double roller, but when I look them up I get many sets to choose from. I am confused...which one do I go with? Any brand better than others? Also I am going with a Hughes Plenum kit or is there another one out there that is better? Also while I am at it should I do the Accel tune up kit? I do pull a 7,000# travel trailer and would like a little more power(I know I am not going to gain much, but every little bit help). Any info you guys could provide me with would be greatly appreciated.
Old 02-20-2016, 07:51 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
For the timing set, pretty much any well respected brand will do ya.
Don't bother with the plenum kit unless you think the aluminum looks pretty. All you need for a permanent fix is shorter bolts.
I don't know what's in an Accel tuneup kit. Ignition modifications will not net you any horsepower gain, so if that's what you're looking for don't bother.
Old 02-21-2016, 03:51 PM
beech2000's Avatar
beech2000
beech2000 is offline
I went with the Cloyes timing set for the 5.7. Also did the water pump, all idler pulley's and tensioner, upper and lower radiator hoses. Everything above was purchased from Rock Auto for under $200. (Gates items).
I used Zerek G-06 coolant and Mobil 1 synthetic for the oil change. All good now. Wait until you see the tensioner in the video. It was in pieces. Don't wait to change.
Old 02-21-2016, 04:50 PM
stewie01's Avatar
stewie01
stewie01 is offline
HEMI 5.7 Broken Timing Chain Tensioner & Replacement DIY - YouTube
I hope you mean 5.9 - Nevermind, two different users.... lol
Old 02-21-2016, 07:50 PM
mattk's Avatar
mattk
mattk is offline
Thanks for the replies guys. I was thinking on going with the Cloyes set...so I went ahead and placed my orders tonight. Timing chain set, tensioner, water pump, among some other maintenance items and went ahead and ordered the Hughes Plenum kit. Just wanted to make sure I was getting all the right parts for the plenum and figured at least with the Hughes kit I know everything is right.
Old 02-21-2016, 08:40 PM
Snowfan's Avatar
Snowfan
Snowfan is offline
100% TRUE. I manufactured plates until it was pointed out to me that the bolt length is too long to achieve proper clamping force. The 'dissimilar metals' theory is bunk. All you need is shorter bolts and clean metal surfaces. Apply a thin layer of black rtv to both sides of entire gasket.
Save your money and help stop the plenum propaganda.
Old 02-21-2016, 11:30 PM
UnregisteredUser
If you're curious enough to search for it, somewhere around here (in the forum) I posted the math that debunks that "just enough knowledge to be dangerous" dissimilar metals myth. Not that it's too hard to get there with the material constants tables if you've got 'em handy.
Good on ya for educating for free when you could profit by exploiting the ignorance of others!
Old 02-21-2016, 11:55 PM
zildjian3707's Avatar
zildjian3707
zildjian3707 is offline
double roller timing chain
Old 02-22-2016, 10:03 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,210 Likes on 2,961 Posts
Totally different engine than the 5.9. The older motors don't have a chain tensioner, and in all reality, with a double roller chain, you should NOT use one. (on the 5.9)
Old 02-22-2016, 10:37 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
I didnt use one. Opened it up to swap a cam 30k later. Still nice and tight
Quick Reply: ?'s About Timing Chain
