engine code PO455 Dodge Ram 1500 V8 Magnum
Old 05-31-2007, 12:42 PM
rough diamond's Avatar
rough diamond
rough diamond is offline
Default engine code PO455 Dodge Ram 1500 V8 Magnum
OK, new to dodge country-I'm trying to find out if anyone knows of areas of the evap system that commonly cause this code to come up. Dealership (not Dodge) is no help at all. I posted in another forum and got really good info. Truck has V8 magnum engine, 2001 less than 100K. Really good truck. I just want to figure out why this check engine light keeps coming on. I've cleared the code and tightened and sealed the gas cap. Still trying to get from the dealership exactly what they've done to the truck. Any ideas would be greatly appreciated.
Old 05-31-2007, 01:19 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
Default RE: engine code PO455 Dodge Ram 1500 V8 Magnum
There is a leak in your Evap System. Could be a disconnected hose, broken connector, etc. There is a purge solenoid in the driver's side rear of the engine that runs a line to the front of the throttle body. Trace the line from the TB back to there and check the connections. Also check the connection and the line from the solenoid back down to the fuel tank.
Old 05-31-2007, 07:36 PM
2001dodgeram1500's Avatar
2001dodgeram1500
2001dodgeram1500 is offline
i guess this code is a emission leak code from what i understand.
Old 06-01-2007, 08:36 PM
WayneC's Avatar
WayneC
WayneC is offline
Major leak in the evap system. Check all your hoses. I'll bet one is completely off or large crack at the connection. Pay close attention to the TOP of the fuel tank where you can't see them until you take them down.
Old 07-15-2011, 11:54 AM
Richie 1's Avatar
Richie 1
Richie 1 is offline
Hi My engine light on my 2002 dodge carivan has been going on and off**for a month now!!
the parts store gave me the code po455 i Put A New Gas CAP On 1 month ago!!!!Help**
Old 07-15-2011, 12:02 PM
A_POLVADO's Avatar
A_POLVADO
A_POLVADO is offline
Pull the canister in the the hoses in there tend to crack and get sponge. took me a year to find my leak and still dont really know what i did to fix it. other than the plenum fix
Old 01-21-2014, 11:33 PM
monterrey's Avatar
monterrey
monterrey is offline
Hi, I have a 2007 doge ram 1500 pick up and the engine light came on, I replaced the gas cap but the light came up again-help
Old 01-22-2014, 10:00 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Get the codes read, and see what they are.
Quick Reply: engine code PO455 Dodge Ram 1500 V8 Magnum
