Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
- Dodge Ram 1994-2001: How to Replace Front Wheel Hub and Bearings
Step by step instructions for the do-it-yourself repairs
Wheel Hub/Bearing DIY
Tools needed
- Air Impact (a must)
- 35mm socket
- 21mm socket
- Torch wrench (one that will go up to 185 Ft/lbs)
- Bearing grease
- Locktite
- PB blaster or any type of penetrating spray
- Bungee cord
- Wire clean up wheel
- Wire brush
- One big sledge hammer (like 20 lbs)
- Some type of torch (map/oxygen or acetylene torch)
- Replacement flange bolts if your old ones are as messed up as mine. Bolt part #06104259AA flange bolt specs 10.9 steel M14 1.50 pitch 50mm length
Step 1.
Jack up truck, put on jack stands, take wheels off
Insert key into ignition and turn to keep the steering from locking up
Step 2.
Remove caliper adapter bolts (2) that are on the back side of the knuckle
Use 21mm Socket and impact gun
Step 3.
Bungee cord the caliper up and out of the way. Avoid pinching the brake hose.
Step 4.
Remove rotor and set aside
Step 5.
Spray axle treads with PB blaster and wire brush threads
Step 6.
Remove axle nut (1) use 35mm Socket
Now for the fun fun fun part
Step 7.
If your bolts have been in as long as mine and rusted like no other you will need the torch for this step.
The wheel bearing is held in by (3) bolts on the back side of the knuckle. use a 21mm socket and impact gun
You will probably need to heat up the end of the bolts that stick out about 1/4" behind the wheel stud plate.
Step 8.
Once you have all three bolts out you will need to hammer the HECK out of the old wheel bearing until it gives in. (mine was rust welded on like no other) This is where the 20 lbs sledge hammer comes into play. Do not be gentle it will give in eventually and start to fall off. Make sure not to hit the axle splines with the wheel hub.
Step 9.
Remove the dust plate
Step 10.
Use wire brush and clean up the knuckle surface and inner mounting surfaces. (do not wire wheel the axle splines)
Step 11.
Use the bearing grease and put a light coat on the splines and the splines inside the new wheel bearings.
**EDIT** I have been told that it is a very good idea to put anti seize inside the knuckle and on the mounting face where the wheel hub touches the knuckle... Guess I will do that next time if I ever have to pull it apart again.
Step 12.
Slide the dust plate and new wheel hub into place (there is no specific position for the wheel hub, it is tri-consintric)
Put the bolts back in with locktite and torque down to 120 Ft/lbs
I found it easiest start the axle nut onto the threads to keep it from falling off while you try and get the bolts started. Make sure you have all three hub bolts installed before you tighten any one down. It is best to bring them in each a little at a time.
Step 13.
Put Axle nut back on and tighten down as much as possible. (will torque later)
Step 14.
Reinstall brake caliper and bolts with locktite and torch to 130 Ft/lbs
Step 15.
Remove center cap from wheel and reinstall the wheels
Step 16.
Once the vehicle is back on the ground you will need to torque the axle nut to 185 Ft/lbs You need to do this when the wheels are back on because you have no other way to keep the axle from spinning besides using the trucks weight and friction of the tire.
Hope this helps someone. It is not that bad of a job. Best part is you do not need to remove the knuckle.
Total job time for me was 5 hours which included clean up. (I am sure I can do it a lot faster next time now that I know how to do it.
Shop wanted $160 a side. Thought I would save a few bucks and be able to do a write up.
- 35mm socket
- 21mm socket
- Bearing grease
- Locktite
- Bungee cord
- Wire brush
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
Step 6.
Step 7.
Step 8.
Step 9.
Step 10.
Step 11.
Step 12.
Step 13.
Step 14.
Step 15.
Step 16.
After I had replaced the lower/upper ball joints, and had an alignment done I still had a random steering walking that I could feel in the steering at highway speeds. I could feel in the steering wheel that a tire, or tires walking/wobbling as I went down the road. hard to explain but if the truck is traveling straight I could feel the tire moving in and out putting slight pull and push on the steering wheel.
No more wheel walking at highway speeds!
I also had a hum that I could not pinpoint.
I still have the hum which might just be the BFG all terrains waring down to a harder rubber.
What was your symptoms for your replacing your axle shaft? Also how is the axle shaft held into the front differential?
Trending Topics
Can you show up in a 4x4 shop with old bearings and take a look if any manual lock can fit in there?
http://www.rearendparts.com/image.php?productid=1249
