Error Codes: P0137, P0440, P0441
Old 04-08-2011, 12:07 PM
okse's Avatar
okse
okse is offline
Default Error Codes: P0137, P0440, P0441
My 2003 1500 5.7 Hemi is pulling the following codes: P0137, P0440, P0441 and after searching I have a few questions.
1. P0137 - is a bad o2 on Bank 1 Sensor 2 is located to the rear of the catalytic converter. Which side Driver or Passenger???
2. P0440 - Gas Cap (REPLACED) and/or EVAP hoses. Should I replace the hoses or EVAP canister, Or Both?
3. P0441 - EVAP Canister blocked and/or Leak Detection Pump or purge connector. Should I replace one by one or all at the same time?
I've done many searches on this thread but can't find the "exact" fix. I will have time this weekend to get this done. I'm no car expert but am willing and able!
Old 04-08-2011, 01:48 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Bank 1 is drivers side. Bank 2 is pass side. Sensor 1 is pre-cat and sensor 2 is post cat.
As for the last 2 codes, you have a leak somewhere. Either in the hoses, the nipples at the end where the connect or a crack in the canister itself
Old 04-08-2011, 03:10 PM
okse's Avatar
okse
okse is offline
Thanks for the quick response. Is the Bank 1 Sensor 2 easy to get to? And, is the EVAP canister on the Driver side between gas tank and back seat with a metal protection frame around it?
Sorry for the questions, I just purchased this truck for cheap(My first truck) from a dude that didn't want to spend time/money fixing it and so I am not familiar with it. But I was able to pull up the codes using the ignition hack.
Thanks again!
Old 04-08-2011, 08:43 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You can use a 3/4" wrench to unscrew the O2 and yes it should be easy to get to.
And you are looking at the right area for the evap can
Old 04-08-2011, 10:06 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
O2 sensors are usually 7/8" are they not?
Old 04-08-2011, 10:34 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Im fairly sure my wrench in my door pocket is 3/4 but then again the other end of that wrench could be 7/8......lol
Old 04-08-2011, 11:54 PM
davb673's Avatar
davb673
davb673 is offline
when I got a 0440, I found the two evap hoses running along the left frame rail next to the cat converter had actually melted and collapsed. Might take a look at those while you are at it...
Old 04-09-2011, 05:26 PM
tmh462's Avatar
tmh462
tmh462 is offline
Just an FYI, bank #1 is always the bank with cylinder #1. It's good to know so you can reference where bank #1 is one Some Other Brands (aka Brand "X").
Old 04-10-2011, 12:49 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
This is true, but most people don't know that even though brand "F" has #1 on the passenger side, if you renumbered the cylinders the same as Dodge/GM, the firing order is actually the same as the 5.0HO, 351W and all of the newer OHC engines (4.6L, 5.0, 5.4L, 6.2L). Just some useless trivia for ya
Quick Reply: Error Codes: P0137, P0440, P0441
