Had a P0420 code pop tonight (2002 Ram 1500)
Just did my tuneup, did not do the O2's yet.. but received the dreaded P0420 code tonight.
It is pretty cold out, I noticed my temp did not get up to true middle (whatever temp that is) and a couple times have smelled a funky exhaust type smell but attributed it to other vehicles around when I smelled it. It being a couple times only, not a consistent exhaust smell (so fits other vehicle's nasty exhaust smell).
Anyway. I am going to go get new O2's and install them tomorrow. I have been using Lucus fuel additive so not sure if I funked up the O2's or the cat possibly?
I know by the condition of everything else the O2's need replaced. Will be doing that first thing in the morning. After buying the truck I decided to pick up the 5-book manual from Dodge. The information is attached for the P0420 out of the manual.
I think it was the Lucus Fuel Cleaner personally. I think it fowled up the O2's. They are more than likely really old if not factory so I figure I would get them anyway. I need to burn a bunch of this fuel off. Didn't know we were getting snow first thing, so I am going to go to a buddy's right now and change them out.
This did get me to going through what I want to do for exhaust. I still don't know how many cats or where they are at. I will find out shortly. I have a plan.
Anyone know which "Y" pipe we use? Do the 4.7 fit the 5.9? How does that work anyway? I see a lot of interchangeable parts that I would have thought would not interchange.. but on exhaust I see a lot of the interchanging but not sure if it is just a "site error" for the vendor sites or what..
Trending Topics
after new gas the MIL light has gone off. I am positive it was the Lucus Fuel Cleaner that fowled up my O2's. I won't be using Lucus again, or if I do way below what they say to use.
I am going to get a few more tank fulls of gas and reset the trouble codes and then I will see what happens. I don't think my cat is bad at all. And don't trust the parts people about the P0420 code being a bad cat. They could honestly care less what it is, and yes most times it is an O2 code and NOT the cat being bad (code).
Will update later.
Will update later.
From the time I made this thread till now I had a P0380 code also which was misfire in #2 cylinder. I just replaced wires and plugs and cap/rotor and coil. I think the lucus fuel injector cleaner screwed things up pretty good. I am going to replace the 02's on friday and will see what that does. I erased the codes tonight, drove it around for a bit and the MIL never came on again. I am thinking the Lucus fouled up the 02's or possibly cleaned out something that fouled up the 02's and then checking the misfire code.. it also states that a bad 02 or (all the parts I swapped out already) or bad cat can be the cause. I honestly don't believe it is a bad cat. I think it is the poor upkeep of the truck by the previous owners and me running cleaner through it that has funked things up.
I will let you know what I find out, but I would rather spend money on a new 02's and have piece of mind that way, then to go and replace the cat and have it still acting wonky and need to replace the 02's afterward anyway. I am working on a process of elimination with less $ first.. first then move up to the expensive stuff. I won't just replace the cats. I will redo the whole damn exhaust before spending what they want on a factory cat. I can get way better with aftermarket cats and for way cheaper.. and to have a higher flowing exhaust to boot.. hey now!
Just the way I do things. Good luck with your code and all. Let me know what you end up finding out, post up what you come up with!
