AC system expansion valve
I had to replace my condensor back in December . I put a new Drier filter on at the same time and put one can of refrigerant in to keep system lubed til warmer weather. Well warmer weather is starting to arrive and went to finish charging the system, but it won't let me add anymore. My intuition (but i'm also very ignorant of AC systems) tells me that my expansion valve is stuck closed. Is there a way to force this to open to allow refrigerant into the rest of the system? My AC clutch seems to cycle fine.
One other question to anyone who might know. My old 97 GC had a dual zone AC system. If I needed to replace the compressor on my 97 single zone, would this compressor work? Thanks to any and all who can help.
RE: AC system expansion valve
What is involved in jumping the low switch. The sytem was depressurized after hitting the deer and I did put 1 can of refrigerant in after the condensor/drier change. Do you know whether the compressor from the dual zone system will work should I need it. Both are 97's with 3.3l motors. Thanks in advance Turbomini.
