DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-03-2008, 05:47 PM
D0TC0M D0TC0M is offline
Default Airbag light lit, what to check before costly dealer service?
I have 2005 Grand Caravan that the airbag light is constantly staying lit. The light was not lit prior to parking it before a big snow storm and the following day the inside of the engine compartment was packed with snow. Prior to starting it I hand removed the snow as much as I could and when I started the van the airbag light stayed on. My first question is, Does the airbag light stay on like the check engine light even if the fault was just intermittent or does the light still being on indicate that the fault is still active. How does the light reset?
If the fault is still there then what checks or troubleshooting can I do i.e. checking connection/connectors, before bringing this van into the dealership and getting dinged with a ridiculous bill?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2005 Grand Caravan Stow n Go
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-04-2008, 11:12 AM
floorslayer1 floorslayer1 is offline
Default RE: Airbag light lit, what to check before costly dealer service?
I'd remove the battery ground for a few minutes and reset the computer. If it is a direct fault of some nature it will come back on quickly. A common airbag light cause is the clockspring in the steering column which had a recall (not sure if the recall applies to your year.) I think the snow was coincidental to the light.
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Old 03-04-2008, 11:48 AM
well I tried disconnecting the negative of the battery for a couple minutes but the dash airbag light stays on. I guess the dealer will have to have a look.
Is there a software alternative that I can use that will get the codes from my dodge? I have tried software but it can only get engine codes.
__________________
Old 03-04-2008, 10:49 PM
richardh05k richardh05k is offline
It will take more than a couple of minutes to discharge the codes. It will probably take over night.
Old 03-04-2008, 11:21 PM
well I checked it this morning and the light was still on. After I got home from work I checked it again and the light was off. I will probably get them to check the codes next time it goes in for service.
__________________
Old 03-05-2008, 12:20 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Clockspring is one of the problem, but so is high resisted at the yellow connectors. The yellow connectors are for the air bag system. You do need to go to the dealer and ck for stored codes.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 03-14-2008, 07:04 PM
pettyrebound pettyrebound is offline
Our 2005 Caravan SE had the Airbag light on when we bought it used.
There was a NTSB recall in August 2007 to rectify this matter.
Our local Dodge dealer handled it fine.
No more Airbag light on.
Hope this helps?
Old 03-15-2008, 09:52 PM
I found corrosion at the two bumper sensors. I disconnected the battery and cleaned the connections and put dielectric grease and everything is back to normal.
__________________
Old 03-16-2008, 05:33 PM
bluecaravan bluecaravan is offline
Thanks for the great info. I think I may have the same problem with the airbag circuit connectors on my 2002 Grand Caravan Sport. The airbag light is on most of the time now, but still goes off occasionally for short periods of time. I replaced the clockspring, even though the hornand cruise control never quit working.
Are the bumper sensors easy to locate?? I will also look for the yellow connectors and clean/grease them with the battery disconnected. Where is a good place topurchase service/parts manuals for my Caravan?
Old 03-16-2008, 06:14 PM
On my Van they are bolted on the frame that holds the radiator. You can see them through the outer most holes in the front bumper (the holes that you can put fog lights in)
Be sure to disconnect the battery for 2 minutes as to disarm the airbag system before working on these sensors.
__________________
Tags
04, 2006, air, airbag, bag, caravan, checking, clockspring, dakota, dodge, light, ram, staying, stays, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
