[1st Gen : 84-90]: Obd2?
After jkeaton's post, I researched and found the procedure you suggest, smokesxt. Those were the 2 codes that came up. 1-2, 5-5. There were no other codes. I, also, realized that I mistook the 'Check Gages' light as being the 'Check Engine' light. 'Check Engine' light is not on, just 'Check Gages'.
So now I have to figure out why the 'check gages' light is on.
There is Oil Temp, Coolant Temp, and Battery Voltage. The needles of the Oil and Coolant are just below halfway. With alternator charging, I checked the voltage at the Battery to be 13.94.
Any suggestions what I should check regarding 'Check Gages'?
Thank you,
Thank you,
Alternator charging voltage is at 13.94.
Daughter has since picked up her van since my last post. I contacted her today and asked if the 'check gages' light is on and if she had fueled the van up. She said 'check gages' light is off and van is fueled up.
It probably was low fuel warning.
Thanks for the idea, smokesxt,
Trending Topics
