Rear Struts
Rear Struts
I need to replace the rear struts on my 2004 Stratus. One wheel is off and I could reove the old strut, except for the bottom bolt. I can't get the bolt all the way out. Not sure of the part name, looks like a control arm lower rear of some type. That arm is in the way. Is there any other way to get enough clearance to get the bottom bolt out without removing that lower arm? If the bolt had beeen put in from the other side I would not have this problem!
that would have been to easy, no that bar is called a lateral link or camber link(deprnding on who you talk to) has to be moved if you take out the bolt closest to tire you can raise it enough to get strut bolt out uses a 3//4 or 19 mm socket, when your putting strut in found it easier to use a screwdriver(lift) and hammerTap) to get it back on lower mount
Do you have the torque spec's for these bolts? 2 bolts on top in trunk, 1 bolt on strut bottom, 1 bolt for the camber link.
Thanks! I'm going to take baby steps with the top bolts. I need the car back in service.I can't wait another week for warranty struts, if I bust the bolt. New struts should be here tomorrow morning, I ordered on line and saved a ton.
I am helping a friend replace a rear strut on his 03 stratus sedan this weekend. It appears the the strut corroded and literally split in two near the top... though it's hard to tell with the tire on.
Would those who have done this please share the procedure with me? I've done struts but not on a stratus.
A few questions on my mind right now:
- What I've done before is to remove the entire strut assembly and remove the spring with a spring compressor once it's off the car. Will that work in this situation?
- assume I need to remove the cover in the back window to get to the strut mount nuts. How do I remove that cover?
- Any other "gotchas" to look out for?
Thanks.
Thanks.
Trending Topics
on
REMOVAL - SHOCK ASSEMBLY
NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
Remove plastic cover from the top of the shock assembly.
Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
Raise vehicle on jackstands or centered on a frame contact type hoist.
Remove the rear wheel and tire assembly from the vehicle.
Remove two fasteners holding the splash shield to the shock assembly upper mount.
Remove bolt attaching shock absorber to rear knuckle.
Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening.
(see thread here)
