2004 Dodge Stratus sputters when A/C is turned on
Old 07-20-2011, 09:34 PM
Bio-Diesel's Avatar
Bio-Diesel
Bio-Diesel is offline
Default 2004 Dodge Stratus sputters when A/C is turned on
I have a 04 Stratus w/ the DOHC 4cyl. When the A/C is turned on the engine will sputter. I have replaced the IAC, and it still does it. The car has 107,000 miles on it and recently I have replaced the plugs, wires, IAC, o2 sensors, and the crank position sensor. I don't know whats up with this car, but everytime something goes wrong with it it never throws a check engine light. It didn't even have a check engine light come on when the o2 sensors went out and the car sputtered so bad you couldn't drive it. Also, something else I have noticed about my problem is that if I disconnect a sensor to purposefully set off the check engine light the car wont sputter when I turn on the A/C.
Old 07-22-2011, 12:58 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Two things, 1st which sensor did you unplug and 2nd does the check engine light do a bulb check when you turn the key on?
Old 07-22-2011, 12:28 PM
Bio-Diesel's Avatar
Bio-Diesel
I unplugged the map sensor. The check engine light does do a blub check when the car is started and is actually on right now due to me unplugging the map sensor. Also a couple weeks ago I unplugged the IAC to see if the check engine light even worked and it set a code then as well. The car didn't start to sputter again with the A/C on after that until I cleared the code.
Old 07-23-2011, 12:34 AM
master tech
Unplugging the map sensor stop the sputting?
Old 07-25-2011, 05:44 PM
Bio-Diesel's Avatar
Bio-Diesel
When I unplugged and then plugged it back in the check engine light came on and it stopped sputtering.
Old 07-29-2011, 02:02 PM
Bio-Diesel's Avatar
Bio-Diesel
any suggestions on what i could check. almost all of my sensors have been replaced and it has had a tune up recently. could it be a problem with the computer?
Old 08-27-2012, 08:06 PM
ShogunChelios's Avatar
ShogunChelios
ShogunChelios is offline
Did you ever find out how to fix that? I'm currently having the same problem.
Old 09-13-2012, 04:39 PM
ShogunChelios
I'm still struggling with it. Luckily (sorta) it got a bit worse, and my check engine light finally came on. The reading says camshaft sensor. I'm in the process of getting it changed it out. I'll update this if it works.
Old 10-05-2012, 11:10 AM
bshany03's Avatar
bshany03
bshany03 is offline
New Member
Having the same problem on a 05. Had the cam sensor changed and it didn't help. Does any one have any suggestions?
Old 08-28-2014, 04:46 PM
fourj_4's Avatar
fourj_4
fourj_4 is offline
same issue never seen that anyone found out what the problem is as I have an 05. Just replaced the Camshaft sensor after the code came on as well.....I was wondering maybe when the mechanic had it played with the timing or setup when on the programmer...Not sure what to do next. I even thought replace PCV Value no help...
Quick Reply: 2004 Dodge Stratus sputters when A/C is turned on
