1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
lebaron trans in avenger
Old Oct 6, 2007 | 06:41 PM
95_dodge_avenger's Avatar
95_dodge_avenger
Default lebaron trans in avenger
can u put a 92 chrysler lebaron transmission in a 95 avenger with a 2.5, if so, is there any mods, and if yes, is it easy?
Old Oct 6, 2007 | 07:05 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: lebaron trans in avenger
no ...
Old Oct 6, 2007 | 07:17 PM
95_dodge_avenger
oh, my sister was wonderin
Old Oct 7, 2007 | 08:14 AM
PappiDread6's Avatar
PappiDread6
Y not I thought the sebring and the v6 venge where the same thing?
Old Oct 7, 2007 | 09:29 AM
bad venge's Avatar
bad venge
Section Moderator
He said a 92 LEBARON .... It's a totally different platform
Old Oct 7, 2007 | 01:28 PM
PappiDread6
Never heard of the car htought it was the type of trans. that was in the sebring. But yeah I looked up the car and I agree.
Old Oct 8, 2007 | 11:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
No the trans will not work. Here is why, The avenger / sebring only had two engines that were stocked. 2.0L and 2.5L. The Lebaron for 1992 had two bodys, (AA) body Lebaron has 2.2 16v turbo , 2.4 turbo , 2.5L all are 4 cylinders. next was 3.0L and 3.3L natural gas. The (AJ) body has 2.4 dohc turbo, and 2.5L. 4cylinders. 3.0L and 3.3L. The bell housings not the same as the avenger. But the all the inside parts are the same. so you could use the clutckes and steel plates as well as the planetary gears and sun gear, and you can use the pump too, but not the torque converter.
Old Oct 9, 2007 | 01:51 AM
gumpster's Avatar
gumpster
Boy, makes one miss the days of the gen1 small block chevy. Even the big blocks had the same bellhouse pattern.
Old Oct 9, 2007 | 07:54 AM
PappiDread6
See thats what i want 2.5L I4 AWD Turbo. I heard that you could get .4L with the bore kit. Anymore you have to worry about overheating and cracks in the walls
