1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Alarm?
Old Oct 15, 2007 | 07:51 PM
Haze99avenger's Avatar
Haze99avenger
Default Alarm?
Do the 99 2.5l come with an alarm or is it an extra, my car locks with the remote, but sometimes when i get into my car my interior lights blink as if there is an alarm but there is no sound. every once in a while when i lock my car with the remote it will make a strange hum noise, sounding some what of a beep that is from a dieing battery or something. Any ideas?
Old Oct 16, 2007 | 12:20 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
factory alarm likely ...
Old Oct 16, 2007 | 05:17 PM
Haze99avenger
Default RE: Alarm?
what do you think the problem could possibly... i thought maybe the alarm horn/speaker is out... not sure though
Old Oct 16, 2007 | 06:05 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
the factory uses one of the two horns, locations vary by year ...
test lock the car by keyless with window down reach in and open the door from inside , that will cause the alarm to go off assuming it's the factory one
Old Oct 16, 2007 | 06:31 PM
Haze99avenger
Default RE: Alarm?
when i do that, this is when the lights on the inside blink as if there is an alarm... but no sounds
Old Oct 16, 2007 | 06:48 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
yup likely the alarm horn is bad (or the relay)...
Old Oct 16, 2007 | 07:04 PM
Haze99avenger
Default RE: Alarm?
and every once in a while there is a hum noise like its a dieing beep when i lock it. where is the relay located for the alarm
Old Oct 16, 2007 | 08:09 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
dunno Mine was ripped out after 2 days
Old Oct 16, 2007 | 08:35 PM
Haze99avenger
Default RE: Alarm?
hmmm is there any one on here who knows where the alarm relay is located on a 99 model... if worse comes to worse im just gonna rip it out and replace it with an aftermarket... pleas help
Old Oct 16, 2007 | 08:37 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
easist way is to set off alarm and feel around under the dash for it ...
also go under the car and look for the horns one is the car horn the other is alarm horn check it for 12 volts when the alarm is going off ... 12v no noise= bad horn ...
