1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Avenger Issue
Old Nov 18, 2007 | 10:12 PM
Tempered's Avatar
Tempered
Default Avenger Issue
98 Sport, V6 2.5..
When in Drive and stopped runs kind of roughly. When I let off the brake it kind of stutters as it goes.
It runs great at all other times. And my Check Engine light flashes (not all the time) just occasionally. And it seems the problem is very occasional as well.
Old Nov 18, 2007 | 10:17 PM
Tempered's Avatar
Tempered
Default RE: Avenger Issue
Also, because the problem just started happening and the check engine light flashes then stops, I cannot use a code reader...
Old Nov 19, 2007 | 10:42 AM
bad venge's Avatar
bad venge
Section Moderator
It stores past codes so they SHOULD be there .... Get the codes then we can giove you better info ...
I'd guess Idle Air Control ....
Old Nov 19, 2007 | 06:42 PM
Tempered's Avatar
Tempered
Alright so it should have the code still there. The check engine light flashes then stops. And I am On my way to autozone every time..
But will stop by right now and fill you in..
Old Nov 19, 2007 | 07:07 PM
Tempered's Avatar
Tempered
The guys at autozone have no clue where to plug the codereader into. So, I took a look and could not find it either. Where exactly is it located?
Old Nov 19, 2007 | 08:01 PM
98silveravenger's Avatar
98silveravenger
Should be under the dash, near the steering wheel.
Old Nov 19, 2007 | 08:46 PM
bad venge's Avatar
bad venge
Section Moderator
middle of the dash really cant miss it ...
Old Nov 19, 2007 | 10:10 PM
Tempered's Avatar
Tempered
Alright will head over there tomorrow after I locate it personally.
Thanks,
Temper
Old Nov 25, 2007 | 11:51 PM
Tempered's Avatar
Tempered
ORIGINAL: bad venge
Well, for some reason they said I had no codes and would pass. I changed the TPS sensor, and found out my battery (bought a bigger one) was grounding out on my hood, so I fixed that. But Still, the car runs AWESOME and idles great MOST of the time. But occasionally (At least twice a day) it idles rough, and when I let off the brake from a stop it bucks a little and then the check engine light flashes. But it doesnt stay on long enough for me to make it to auto zone (I live right down the road).
I also have the Idle Air Control sensor, but havent installed it yet.
Old Nov 26, 2007 | 04:26 PM
slowta's Avatar
slowta
Without knowing more about the problem, but if it is only having problems with the brakes on, check for a leak in the brake booster line. Plug off at the engine and try. Braking will be very hard if any.
