1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
2000 venger no spark
Old 02-08-2008, 07:09 PM
dbollinger1's Avatar
dbollinger1
dbollinger1 is offline
Default 2000 venger no spark
this car was running we parked it the got back in it couple hours later and it wouldnt start it turns over but acts like its not getting spark there is no check lights on the last time it did this was a hit and miss thing about two years ago it would run fine then at times it wouldnt run i found it to be the crank positioning censor this time it gave me no warning at all just wont start loooks like no spark any ideas im on my way to get a replacement cps at this point ill check back soon for help or if it works after
Old 02-08-2008, 09:15 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
Default RE: 2000 venger no spark
There is a cps test procedure above it's likely that or the relaysalso posted above
Old 02-08-2008, 10:56 PM
dbollinger1
cps was a no go put new on in still not starting i here clicking under hood but i believe im not hearing the fuel pump
Old 02-09-2008, 05:24 AM
dbollinger1
check fuel pump it has fuel coming out the tank i unhooked line on top of tank and turned key the fuel is there when key is on
Old 02-09-2008, 11:18 PM
dbollinger1
i changed the plugs the day before this started could the time have jumped?
Old 02-09-2008, 11:38 PM
bad venge's Avatar
bad venge
Section Moderator
changing plugs has nothing to do with timing ... Did you do cap/Rotor???
Old 02-09-2008, 11:44 PM
dbollinger1
thanks for the help if it wasnt for this board and nice people like your self id be lost
no on the cap and rotor there was one plug front bank on the right that got closed up during install
when i fired the car up it was missing and the check engine light flashed i turned it off found the plug problem fixed it then it ran great more power than before the next day she drove it once it was fine then later tht day it just wouldnt start
Old 02-10-2008, 10:40 AM
bad venge's Avatar
bad venge
Section Moderator
OK your positive the fuel pump is running ???
How many miles on the car ???
How long since the cap/rotor changed???
Old 02-10-2008, 07:13 PM
dbollinger1
cap and rotor done maybe year ago maybe alittle longer
the fuel im not sure i opened the fuel line back on the top of the tank and turned the key on and a good amount of fuel came out im not sure if its reaching the fuel rail or not i also cant hear the fuel pump running there are no codes comeing out of it as of yet
Old 02-10-2008, 07:15 PM
dbollinger1
miles on car are around 116,000
Quick Reply: 2000 venger no spark
