1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
trans stuck in second, searched but no one is having the same prob as me...
Old Feb 20, 2008 | 12:31 AM
TheZephire's Avatar
TheZephire
Default trans stuck in second, searched but no one is having the same prob as me...
ok so my car was driving all fine and dandy eversince i bought it in november, today i was driving and my car jerked when i was decellerating and i thought nothing of it, then when i went to accel my car was stuck in second, i read thats limp mode. well, if i pull over just shut off the car and restart the car ( even with no wait time ) the car shifts again like nothing is wrong for a little bit, then just reverts to staying in second gear. so what could it be? why would it just stop? firewall relays? tcm? please help.
Old Feb 20, 2008 | 12:23 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: trans stuck in second, searched but no one is having the same prob as me...
You'll need to get the codes ... Without codes we can guess all day
Old Feb 20, 2008 | 01:23 PM
TheZephire's Avatar
TheZephire
my check engine light isnt on, and im guessing to get codes you go ON OF ON OFF ON and its supposed to blink codes, well, my car doesnt blink any codes. when i tryed to get the codes when my check engine light was on for my 02 sensors it would not flash any codes.
Old Feb 20, 2008 | 02:02 PM
bad venge's Avatar
bad venge
Section Moderator
No you need the TRANNY codes ...
Old Feb 20, 2008 | 03:19 PM
TheZephire's Avatar
TheZephire
what i am saying is my car does not flash codes, i get it, my trans is messed so i need the trans codes. but my car does not flash codes for anything, should i just go to autozone and have them scan it? can they scan a 95 venge?
Old Feb 20, 2008 | 04:51 PM
bad venge's Avatar
bad venge
Section Moderator
I'm not sure if they can scan the tranny ... I had a tranny shop do it
Old Feb 20, 2008 | 05:39 PM
TheZephire's Avatar
TheZephire
alright, so i went to aamco, they checked my car. They say "your solenoids are good, you have no leaks, your oil is bad, its tarnished and you have foreign debre in it, your trans does not want to go into 3rd or 4th, so your car goes into limp mode, so you need a new 3rd and 4th gear". i don't believe it, i know my oil was bad, i think i would know if i dropped gears. im going to change my firewall relays, ( just want to make sure ), get a input and output speed sensor ( starting with the cheapest ) if that don't fix it, then i guess the shop told the truth.
Old Feb 21, 2008 | 03:56 AM
coloradovendge's Avatar
coloradovendge
Had same issue with my 98. Tranny was over heating when I hit the mountains, I installed a aftermarket tranny cooler and have not had any problems since.
Old Feb 21, 2008 | 10:04 AM
master tech's Avatar
master tech
Site Moderator & Tech
The avengers will not flash transmission codes, but ifyou lost 3rd and 4th gear you may have a broken hub/w shaft. The trans would need to come out for repairs.
Old Feb 21, 2008 | 12:48 PM
TheZephire's Avatar
TheZephire
wouldent you know if you blew gears? i barley felt anything.
