1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
avenger won't start
Old Apr 7, 2008 | 12:17 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: avenger won't start
In dodges infinite wisedom the car must see fuel pressure before turning over , no fuel pressure the ASD relay engages and kills starter function
Old Apr 7, 2008 | 01:01 PM
Sroufe7's Avatar
Sroufe7
How does the car know if there is fuel pressure?
Old Apr 9, 2008 | 10:42 AM
varmintjcl's Avatar
varmintjcl
My 96 2.5 wouldn't start, but it turned over fine. I sprayed a shot of starter fluid in the intake & it fired, so I replaced the fuel pump & it started right up. So I don't know how those dumb electronics work, but mine had 0 fuel pressure & still turned over fine.
Old Apr 11, 2008 | 08:35 AM
95_dodge_avenger's Avatar
95_dodge_avenger
does the engine attempt to crank, i just got out of collage, taught by a dodge dealer
Old Apr 11, 2008 | 03:04 PM
darkestxxnight's Avatar
darkestxxnight
you mean you just got out of collEge?
Old Apr 14, 2008 | 08:51 PM
boost creep's Avatar
boost creep
ORIGINAL: bad venge
then how is it i can disconnect power to my fuel pump and crank the engine to depressurize my fuel system?
