1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Need help with 1995 avenger
Old Apr 18, 2009 | 08:32 PM
rudegirl's Avatar
rudegirl
Default Need help with 1995 avenger
recently purchased a 1995 avenger and it has been running rough. also when i reach speed of 40 to 60 kms it will start to jerk and if i speed up or slow down it stops.. when i speed up it revs high and then takes off. Is this a tranny problem? also need to find out which fuse is for the tail lights as i don't have a diagram.. any help is greatly appreciated
Old Apr 18, 2009 | 08:39 PM
Killa200's Avatar
Killa200
Does it also have a rough idle? I recommend running some seafoam through the intake plenum via a vacuum line first off and see if that cleans up things a little bit.
Old Apr 18, 2009 | 08:48 PM
Mavman's Avatar
Mavman
Default okay.....
First off check the tranny fluid. I once accidently didnt put enough fluid in when i did a change and it did that. needless to say it didnt hurt it when i did it. DO THIS IMMEDIATELY!!! The trannies in our cars are extremely rare due to a housing swap in the early productions. Hopefully if something does happen you have a late production 95 unlike mine. Check that first and if that seems fine post back. I have to run right now.
Old Apr 18, 2009 | 09:01 PM
rudegirl's Avatar
rudegirl
Smile
Hi, it does have a rough idle . will check the tranny fluid again..was told when i bought it that it had new wires and plugs but needed a distributor cap so i replaced that as well as the rotor..still runs rough.. Idles at 500 rpm's and feels like it wants to stall when stopped.. thanks for the help
Old Apr 18, 2009 | 09:12 PM
Killa200's Avatar
Killa200
yeah i would definitely go with the seafoam though the vacuum line. Sounds like perhaps a dirty IAC.
Old Apr 18, 2009 | 09:44 PM
bad venge's Avatar
bad venge
Section Moderator
Run the seafoam and also remove and clean the EGR valve
Old Apr 18, 2009 | 10:16 PM
candacebadie's Avatar
candacebadie
Try changing your battery terminals and charging the battery. My car ran the same way, idling very low and almost cutting off with heavy loads and when braking while turning.
Old Apr 20, 2009 | 01:08 PM
COYOTE102076's Avatar
COYOTE102076
Make sure your battery is of the correct size as well! Found this out when I first bought mine. My battery checked out OK, so I thought nothing else of it. When I came back around to the battery, I found out the previous owner had put a battery on it that was too small. Per our INterstate Battery application book: If your car is a convertable, it needs a batttery with a BCI GROUP 75 ( Interstate battery# MT-75 ) If your car is a hardtop, it uses a BCI GROUP 86 ( Interstate battery # MT-86 )
If the battery is to small it will not supply enough power to run all the electronics on the engine.
