Major issues, please help!!!
Alright, this is a "fun" one! 95 2.0L, 162K I just recently started hearing a loud squeak noise when turning right. Anyone know of any common problems for bushings in the steering system or might it be something else...?
The other problem I have is quite unique, at least I think it is. I'll be driving (it happens during idle or maintaining a certain RPM) and the gauges will all of a sudden drop to zero on everything and all the lights come on, as if you had turned the key on, but not started the car...here's the weird part though, the engine is still running but I have no throttle response. It's got me guessing pretty good, but it won't throw a code for me at all. If I turn the key back one position then on again, it comes back to life and acts as if nothing happened. I really don't get it! Any help would be much appreciated! Thanks in advance.
Well, the car completely quit on me now, driving down the freeway and everything shut off. I noticed when I turn to key to the on position the check engine light doesn't light up and all the car will do when I try to start it is crank. I already replaced the ignition switch, but I may have a power issue. Could it be a relay of some kind, like maybe the ASD or something?
any help is much appreciated on this one!
Trending Topics
