How many avenger owners
RE: How many avenger owners
ORIGINAL: 9avenger7
Even later but..
97 Avenger ES V6..amazing car, but i'm having a hell of a time finding performance parts for it
Even later but..
Trending Topics
1995 Forest Green Avenger V6 Turbo
2.25" ERT Custom charge pipe
2.5" ERT Custom downpipe
ERT Direct fit 2.5" high flow cat
ERT 304 Stainless 2.5" Catback
Magnaflow Muffler
Garrett GT32 Turbocharger
Tial 38MM Wastegate
Braided feed and drain oil lines
Oil filter relocation kit
Braided fuel lines
HRC Front Mount Intercooler
ERT Upper Intercooler piping
ERT Lower Intercooler piping
Thermotec Hose Sleeves
TurboXS Type RFL blow off valve
Joe P Manual Boost Controller
Accel 300+ Thundersport Wires
NGK copper plugs (.035 gap)one range colder
MSD 6A Ignition
MSD Blaster 3 Coil and tower
ERT Modified Distributor Cap
ERT Modified Accel 26lb Injectors
Vortech SFMU Fuel Regulator
Autometer Ultralite Boost Gauge
Autometer Ultralite EGT Gauge
Autometer Ultralite Electric Fuel pressure gauge
Autometer Ultralite Oil pressure gauge
Modified Air Fuel Gauge
Autometer Guage bezel
Lotek 3 Pod Gauge pillar
Dual 950cfm Radiator Fans
Ingalls Camber Kits
Eibach Pro Kit Springs
Raybestos Carbon-Kevlar Clutches
TransGo Shift Kit
ERT 2500RPM Converter
TCI 6-Pass Trans Cooler
2006 Setup Being Built
6G72 3.0L Engine, stock internals
Fidanza Adjustable Cam Gears
ERT Custom Ceramic Coated Turbo Headers
Ceramic Coated Turbo Collector
3" Ceramic Coated Turbo Downpipe
ERT Direct fit 3.00" high flow cat
ERT Predator 3.00" Catback System
Ceramic Coated/ Polished Garrett GT Turbocharger
ERT Stainless Turbo Heatshield
Tial 38MM Wastegate
ERT Oil Cooler Kit
ERT Pro-Billet Fuel System
ERT Aluminum Upper Intercooler piping
ERT Aluminum Lower Intercooler piping
Forge Motorsport Racing Dump Valve
MSD 6A Ignition
ERT 525CC Fuel Injectors
ERT Piggyback ECM
2.5BAR MAP Sensor
Autometer Ultralite Electric Oil pressure gauge
AEM UEGO Wideband Gauge
Dual 1050cfm Radiator Fans
Ingalls Camber Kits
5speed Conversion
ERT Crankshaft Sensor Relocation Kit
Spec Stg III Clutch with upgraded pressure plate
GSX Front Calipers and Dimpled/Slotted Rotors
Rear Dimpled Slotted Rotors
Hawk Performance Pads
Stainless Steel Braided Brake Lines
1995 Black on Grey Sebring LXi
Low and slow.
