1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Problem with Transmission :icon_doh:
Old May 8, 2012 | 02:58 PM
Mikee06's Avatar
Mikee06
Ya well I'm not for sure if it's coming out of the plate... I had it off & the car was running I could see the torque converter turning while car was running & didnt see any spraying all over the place or anything but saw leaks on the back end of the block on the side still where that inspection cover goes it was leaking none stop & while I drive leaks alot... what does the torque converter do? does it it keep all the transmission fluid in it or something?? I Replace the Seal after you take off the torque converter there dont know if that the problem or what?
Old May 8, 2012 | 03:06 PM
Mikee06's Avatar
Mikee06
That would be the only thing it would come out of right the torque converter?? I dont know if the transmission fluid goes into any pumps or anything like that..that making my transmission leak on the side??
Old May 8, 2012 | 03:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
No, it could be the front pump gasket that is leaking.
Old May 8, 2012 | 03:47 PM
bad venge's Avatar
bad venge
Section Moderator
AGAIN Post a picture ... We can guess all day long without a picture it's just a guess...
Old May 8, 2012 | 11:59 PM
Mikee06's Avatar
Mikee06
oh ya what does that look like & how much do they go for?? Can't find anything on what it looks like & I will get some Pictures soon when I can Srry bout that & how do I post Images on here I dont see an upload pic here...
Old May 9, 2012 | 03:16 PM
Mikee06's Avatar
Mikee06
I got some Pictures how do I post them?? Thanks Mike
Old May 9, 2012 | 04:02 PM
bad venge's Avatar
bad venge
Section Moderator
Host then to photobucket and provide a link to it is the easiest way
Old May 9, 2012 | 05:11 PM
Mikee06's Avatar
Mikee06
Ok thanks here are the Photos of the Block
http://s1266.photobucket.com/albums/jj530/Raildawg06/
Old May 9, 2012 | 09:05 PM
Mikee06's Avatar
Mikee06
Can you see the Pictures I have Posted?? that is the transmission block that leaks you can see transmission fluid all over the place dripping...
Old May 9, 2012 | 09:07 PM
bad venge's Avatar
bad venge
Section Moderator
the 192 picture where the 2 drops reside it appears like theres a crack there (might be discolored) theres also a gouge like a bolt hit it
