1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
99 Avenger issue - AGAIN!
Old Apr 25, 2014 | 10:27 AM
wrongturn's Avatar
wrongturn
Unhappy 99 Avenger issue - AGAIN!
Greetings out there in Avenger land. I last posted in 8/2012. My 1999 Avenger, 2.5 V6 had engine misfire issues. After all of the hours spend checking this and that, it ended up being a bad distributor!
Thanks for your help, Bad Venge!
A year and a half later, I now have a new issue. No power when climbing hills, any hill. If I play with the throttle as I am climbing a hill, it will eventually gain some speed. Currently CEL is not on. Engine does not miss, it idles fine. I have not checked much yet.
Does anyone know a easy way to test fuel pressure?
ANY HELP WOULD BE GREAT!
Old Apr 25, 2014 | 07:44 PM
bad venge's Avatar
bad venge
Section Moderator
does the car have power on flat roads?
Old Apr 26, 2014 | 06:53 AM
wrongturn's Avatar
wrongturn
There is a reduction in acceleration on flat roads.
Old Apr 27, 2014 | 11:23 PM
simmonsfr's Avatar
simmonsfr
I would look at the simple things first. Sounds like fuel filter or maybe the rare clogged air filter. Sounds like your engine is not getting enough fuel or air.
Old Apr 28, 2014 | 12:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Could be plugged exhaust system. Try removing the o2 sensors and drive the vehicle and see if power.
Old Apr 28, 2014 | 12:35 AM
djbucky3's Avatar
djbucky3
To help out the OP, he did ask if anyone knew how to check the fuel pressure. I am unaware of the process, but maybe someone can enlighten him or send him in the right direction?
Old Apr 28, 2014 | 09:08 AM
wrongturn's Avatar
wrongturn
Thanks to all for the suggestions. I have removed the fuel filter, its looks like it could be the problem. Gas from the filter is gray in color. I will also take a look inside the tank. I will also check the air filter, we live in the woods in WV, lots of varmints.
Old Apr 28, 2014 | 08:05 PM
master tech
Then to check fuel pressure, I believe you need a banjo fitting and adapter to screw into the fuel filter. That's was how we check them when the car first came out.
