Severe coolant leak...and more?
First of all i would like to say that I am new here, so i apologize if i am posting in the wrong place.
I was just given a '98 Avenger by a friend because, basically he doesn't want to deal with it...
From his description the car stalled out and wouldn't start, when he checked, it was pouring coolant out from under the engine.
Since i have had it, i tried to refill the coolant. As soon as coolant is put in it pours out the bottom of the engine compartment, from what seems to be near the front (Crank pulley) area. At this point i am assuming it is a problem with the water pump, though i can't really tell with the timing cover on. I would like to hear any other thoughts on this before i go blindly turning wrench.
Also i am woried that if the pump seized up, then it may have thrown the timing severely off as the car will turn over but won't fire up when I attempted to start it. And if this is true, that it may have caused some damage to the valve train.
So my question is is anyone else familiar with this type of issue, or had it happen, that can point me in the right direction, as i can't afford to just throw a bunch of money at it, but i am dying to get this puppy on the road.
Thanks for the help.
RE: Severe coolant leak...and more?
It has the 2.0 I4.
so far as i have gathered from the previous owner, the car was runnning fine before this occurence, with no warning lights and such either.
I don't know if the water pump pulley is turning, i haven't yet removed the timing cover.
And there appears to be no traces of water and oil mixing, such as milkiness, in either the oil or coolant.
the water pump will still turn in the i4 but it will puke all around the shaft....first check the radiator and hoses
easiest thing to do is just take em out hold your hand over the bottom waterneck and fill with water hoses are obvious
if theyre fine go to the waterpipes in the front ...they have a tendancey to rust out
then rinse everything down and allow to dry....attempt to refill coolant and watch block dfrom wheel well and you should be able t find the answer
ok here's the update:
I have now removed the wheel, inner fender well cover, and accessory belts. When i put coolant in it seems to be pouring from behind the crank pulley, i don't see any indicator of it leaking from the water pump area and leaking down from there....please help me?!?
What would this sound like to you as being the cause? ways to test different possibilities? and repair procedures?
Sorry for being such a newb, i really appreciate all the help. thanks.
Trending Topics
