Need help ASAP please 88 dakota
I have a 88 dakota 4x4 3.9 build date 10/87...this truck is different than any dakota I came across, heavy duty cap, bigger radiator etc....
started acted up last week, hard to start after driving, dies when driving, got it to work yesterday, and it wouldnt start back up, went through faq's searched etc
Replaced, coil, plugs, wires, cap, rotor, iac....ran fine started burning oil on way home then died while driving...towed it home, sat over night, started truck this morning moved it now wont start, cranks bbut no spark....
PCM? Igntion pick up asembly? any other ideas? need to get running asap, as I cant get to work
No spark from coil to distributor, no spark to cylinders, yes the rotor turns when you crank engine. Ran like a new truck for 11 miles yesterday after new plugs wires coil cap and rotor.
couldnt find any bad wires on left side going up towards battery, took off washer jug, tried a new regulator on the bulkhead just now, leaning towards ignition pick up assembly or pcm....but dont wanna keep throwing parts at it
Update....well now I feel like an idiot, after all the parts I threw at the truck I put a new stator in tonight after work, started ten dies, then just cranked and cranked.....after cussing and saying whats going on, i look at a relay on the left front fender....cracked andnot all the way in.... push it in truck starts and runs fine, pull relay truck des, then just cranks
now my question is was it a fuel pump relay, or the auto shutdown relay
Trending Topics
